sssooo
Ohio
I did check the GFI in the bathroom but I will look to see if there are anymore !
but that sounds like that is what it could be
patnchris
Gurnee, Il. USA
I had one of the wires on my GFCI come loose. Made me crazy, as the GFI outlet was working perfectly, but the additional outlets that were protected by it, were all dead. It would have been nice if there was a list of which outlets wsere controlled by which GFCI.....It would have made tracking down the problem a lot easier......Pat
Patrick and Christine
and Maggie May, the cocker spaniel
1995 Damon Ultrasport 3470
Rallies Attended "21"
bsprague
Milton, WA
sssooo wrote: I did check the GFI in the bathroom but I will look to see if there are anymore !
I have one in the basement that is the first outlet in the line for several outlets and a light inside. It likes to trip during the change over from Onan to inverter.
GFIs are fine in a house where the power typically comes from the same source. In my motorhome the GFIs act up when swithching between shore, inverter and Onan power.
Bill Sprague
2004 Beaver Monterey, 8.3 ISC 350 Cummins
2007 Ford Edge AWD
9 ft Quicksilver inflatable boat w/ 15 hp Suzuki
SteveRuff
Bacliff, Texas, USA
Good Sam RV Club
I had the same problem. Checked and found a tripped breaker on the generator. Went back in to find some worked others were still out. Closer examination showed a 20 amp and a 30 amp breaker on the generator. The 20 amp didn't look tripped but it was not "tight." Set them both and all was good inside.
Both retired. Travel with Nicky the Schnoodle. Son graduated and is teaching high school math. We notice he still prefers to use our checkbook! We still love our 2006 34' Allegro Bay XB and have 25,000+ miles on her.
Jack/Chris
Stockbridge, Ga.
Good Sam RV Club
If your coach has a inverter, try reseting the breaker.
Jack and Chris
2002 36' Dolphin
Saturn VUE Tow
Wherever I happen to park
bsprague wrote: What happened to your wife that a GFI saved her? And, I don't remember what "ROFL" means!
I see question 2 has been answered....
In our house the bathroom outlet is way too close to the shower, I originally put a shield over it but when I had the tub area re-done they did not re-build the shield, so I swapped the outlet for a GFCI
Well Wife is rinsing down the shower walls and sure as shooting she shot a stream of water right into the outlet CLICK and darkness ensued
She is the kind of person who thinks... Later
Switchman
Mercerville, New Jersey
Good Sam RV Club
In our '04 Bounder there is a switch just inside the doors under the kitchen sink. Check and see if they are set for the micro wave. If not that could be your problem.
Owen & Barb
2004 Bounder 36S Workhorse W22
2001 Saturn SL2 - Toad
Co-pilot Live Laptop 10 - GPS
MSGT, USAF (Ret)
FurKids:
Want to be a lap dog, Rod-Black Lab mix named: Hollie:
A deaf lap dog, Chihuahua named: Chicky
FMCA F386249 - Good Sam Club
jjammo
Medford, OR
Good Sam RV Club
I'd go for the reset button on your inverter. That was my problem "AFTER" calling out a repairman. Even took him awhile to discover it.
USAF Retired
99 Nat'l Tropical,36',F53,V10,1-slide,Tag axle
Patty-O-Room
03 Ford Ranger,4x4,auto w/Remco, air-lift susp.
Brake Buddy Classic
Port-A-Bote
09 Polaris Ranger RZR 800
sssooo
Ohio
went and reset the GFI afew times that had to be it and yes Switchman I forgot all about that switch that was it for the microwave, "MY BAD"
thanks all
Chief enforcer
Interlaken N.J. U.S.A.
Good Sam RV Club
No problem! That's one of the nice things about this forum; getting imput from others that have been through the same thing!
