RV.Net Open Roads Forum: Class A Motorhomes: Jacks & slides don't work
 > Jacks & slides don't work
flrvman
Posted: 12/27/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have a friend who has a Itasca Suncruiser. Slides and jacks stoped working. Seems to me it must be an electrical problem.  Does anyone have any ideas as to where the problem is. This guy is a pretty good electrition. May not be connected but it seems strange that they both quit. Thanks for any help.
2007 B+ Lexington GTS 300SS Blue & Grey Ford V-10
2005 Malibu LT V6 toad
hottubkid
SCHAUMBURG,IL
Posted: 12/27/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Check to make sure the e brake is on.
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
BarbaraOK
Livingston, Texas, USA
Posted: 12/27/08 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
HWH levers and slide mechanism? If so, has he called them. Did they stop working so he can't bring the slides in and levers up or the other way around. Does he get a battery low warning? ETC.?
Barb
Barb & Dave - full-timing
Traveling catpanion Shadow (age 12)
Figment II (2002 Alpine 36 MDDS)
Mischief
(2004 Subaru Forester Toad)
FMCA - F337834, SKP #90761
Our Blog
Motorhome05
Los Banos, Ca
Posted: 12/27/08 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
check the batteries. Our slides will not work if the batteries are low.
Motorhome05
Escapee
FMCA
Lifetime Good Sam
2005 Winnebago 36' Vectra GD
www.onthegowithgaryandjo.blogspot.com
Fulltime Graduation Rally-Quartzsite Jan '06
rkcg@concentric.net
Dunn, NC 28334
Posted: 12/27/08 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Or maybe someone has turned the battery disconnect switch to the off position.
Clubmagic
rvtommy
blooming prairie minnesota
Posted: 12/28/08 05:58am Link  |  Quote  |  Print  |  Notify Moderator
I once had a bad slide switch!!! Sometimes the slide would go and sometimes not I would keep playing with the switch untill it worked. Al went well until I burned out the hyd. pump!!! The mecanic said if I would have replaced the switch it would of saved me alot of money. Sorry my vote is check the pump if the other things have all been done. We were in San Jose Ca. when this happened only a mile and a half from Leiles repair had wife follow it was quite a sight driving down the busy road with all slides out!!!! Happy New Year rvtommy
this is rvtommy
kalynzoo
Los Angeles , California
Posted: 12/28/08 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Similar problem this summer with an Adventurer (also Winnebago). It was suggested I move the MH slightly to vibrate in the loose contact. It worked, but I realized that what I really did was start the engine, idle for a while, and then activated everything with a full battery charge. Playing around with the problem made me realize that my batteries were maintaining at 12.5 to 12.7 when plugged in. This apparently is not enough juice to activate the systems. Then again, maybe I am missing it altogether, and starting the MH jiggles something. At any rate, starting and idling before bringing in the sides and bringing up the jacks, after a prolonged stay, seems to work for me.
horizon451
Henderson, NV
Good Sam RV Club
Posted: 12/28/08 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Check for 12 volts at the pump motor first. To do this, have someone try to operate either the jacks or slide(s) while you take the measurement. If you have power there is a good chance that the motor is shot. If no power, check the fuses. They are disguised as lumps on the wires near the motor. Another place to look is the control box. Unplug and replug it to confirm good connections. If you have not determined the problem, call HWH. They will ask if you have done the above first. This happened to me and it turned out to be the motor.
Good luck.
'02 Itasca Horizon 36LD
'02 Jeep GC toad
flrvman
Posted: 12/28/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks horizon451. We will check this out in the morning. Sounds like you nailed the problem.
mpmeisch
Arlington, TN formally Aurora, IL
Good Sam RV Club
Posted: 12/28/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
On the suncruiser, you have to have the key in the ignition and turned to on to run the jacks, also the parking brake must be on or they won't operate. Both systems are on the chasis/engine battery so the position of the battery cutoff should not matter. I believe there are 2 different pumps for these systems so I would suspect the engine battery being weak. Something is getting the 12 volts to the pumps.
Flying for work, cruisin' for fun!
2001 Itasca Suncruiser
