ventrman
Erin, TN
I finally took the plunge and got Microsoft Streets and Trips.
I have one question. It says that my GPS Antenna needs to be connected to COM5. How do I determine which of my USB ports is COM5?
God Bless!
SAR Tracker
sounds like you need to re-install the drivers that let the GPS talk to the software..... that'll allow the plug and play functions.
Rusty & Cheryl & Serendipity (dog & Chief Security Officer)
2000 F150 4x4 5.4L/3.55 (117k miles and goin' STRONG!)
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
cleo43
Montreal
This site has lot of info about S&T.
JFG
TN
Mine works on either one.
Fred
Bob N Deb
B.C.
once you get it going let us know how you like it .
I have used an older version and am in the market for a new version or a new gps.can't decide which.
Dandy Dan
Findlay, Ohio
Good Sam RV Club
Ventrman, I installed MS&T on my laptop to use in the tow vehicle. I installed the program and plugged in the antenna into 1 of the 2 USB ports and it took right off. I had the 2006 version and upgraded to the 2008 version which was quite a bit better on having roads where they actually are. I like it because it gives me a larger screen area to look at than the smaller GPS units. Since I take a saptop with me in the 5er it seemed that was the right choice rather than buying another electronic unit. I hve seen the upgrades to MS&T for $39 to upgrade to the latest version out. Good Luck and Happy Camping
dan218b@tds.net
Dan and Lori Branson
Anna 1 (the rescue) Sarah (the rescue)
and Beau (waiting at the Rainbow Bridge)
2005 Dodge QuadCab 2500 4x4 Hemi
2009 Open Range 337RLS
RV.Net Ohio Rally Member
H & R
Winnipeg
Good Sam RV Club
My experience was that the first time I installed Streets & Trips with the GPS receiver plugged in the USB port prior to installation. This did not work. I uninstalled and installed it again without the receiver plugged in. Then I plugged in the receiver to one of the USB ports ( I was in a place where a single was available - not in the house). Then I had to use the configure GPS button and after a short time a menu came up showing which port was occupied by the receiver and I highlighted it and I believe said OK. I now always use the same port and have no problem but once in a while I need to configure the GPS again.
Hope this helps.
edited 12/31/08 02:27pm by H & R *
Harold & Regina & 1 choc lab
2003 Dodge 2500 4 X 4 Crew Cab Diesel short box
2005 Keystone/Springdale 31 Ft 5'er 280 FWIKL-GL
