RV.Net Open Roads Forum: Tech Issues: adding electric outlet
 > adding electric outlet
Tech Issues Related Tips
ChipA
Wetumpka
Posted: 01/04/09 08:56am Link  |  Quote  |  Print  |  Notify Moderator
LED is the way to go. 12V is readily available. I wanted a night light in the bathroom so when I got up during the night to go I would not have to turn on the regular bright light. I added another switch to the bathroom light switch and added a red LED light that was suppose to be a trailer clearence light. I choose red from my military days in our equipment vans for night operations. Works great for me.
2004 Chevy Silverado 2500 HD Crew Cab 4X4 8.1L
2007 Keystone Challenger 35CKQ 4 Slides
Bumpyroad
Virginia
Posted: 01/04/09 09:24am Link  |  Quote  |  Print  |  Notify Moderator
well if you always stay at campgrounds with 120v like I do I just put a small photocell operated tiny nightlight in my bath. At home I have one and replaced the standard 7 watt?? christmas tree bulb with a 4 watter??. they make lots of small ones with LEDs also.
bumpy
ChipA
Wetumpka
Posted: 01/04/09 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
That would work but in my case there is no outlet in the bathroom like the OP said. Besides, I can still use it when on 12V and with the switch I can turn it on and off as needed to save the battery. I mounted mine under the cabinet over the toilet that way it is out of sight and will not shine directly in your eyes.
Bumpyroad
Virginia
Posted: 01/05/09 04:54am Link  |  Quote  |  Print  |  Notify Moderator
out of curiosity, do they make a lot of 5ers without a 120 outlet in the bath? doesn't anybody who owns a 5er shave with an electric razor? If I didn't have an outlet in the bath, I think that would be my first project, installing one, nightlight or not.
bumpy
ChipA
Wetumpka
Posted: 01/05/09 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I guess that depends on how you define bathroom. I both of my fivers and one TT the toilet was in a room by itself. The sink and mirror are part of the bedroom. There is an outlet at the sinn and mirror. I was talking about the room with the toilet, just a toilet.
Bumpyroad
Virginia
Posted: 01/06/09 05:19am Link  |  Quote  |  Print  |  Notify Moderator
then you obviously need a reading light.
bumpy
Bob Landry
Austin, texas
Posted: 01/06/09 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Going back to the original post, since this one got hijacked by the LED inthusists....
You said yoou are tapping into a bathroom outlet and adding another outlet on the other side. Do some looking around. I woud be surprised if the bathroom outlet isn't already protected by a GFI. In marine heads, the BR always has a GFI beause there's a shock hazard around water. If it isn't, it should be for safety. Make the bathroom outlet a GFI then go to the other side and cut the hole for the new outlet and install a standard outlet. Be sure to observe the Line/Load connections. The bedroom doesn't need GFI protection. A LED would work, but it will be easier to tap into an outlet on the other side of the wall than to try to trace down a 12V line and make a clean connection there. A wiring diagram of your trailer would be helpful if that's what you decide to do. If you are staying in parks, power comsumption of a 110v night light means little and you have an additional outlet that can be used for other things also..
Bumpyroad
Virginia
Posted: 01/06/09 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I notice in Lowe's that they now have a special G?I type outlet designed for bedrooms.
bumpy
lefty6262
Anderson Indiana
Posted: 01/06/09 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I have the 12 v ceiling vent fan. would it be possible to connect to that wiring to put a nite lite on the ceiling?
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 01/06/09 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Lefty: The answer is YES!
Bud
Suzuki XL7 pushing Pace Arrow
