RV.Net Open Roads Forum: Onboard Air Compressor used to Inflate Stuff
 > Onboard Air Compressor used to Inflate Stuff
General RVing Issues Related Tips
Tizi
Puyallup, WA
Posted: 01/09/09 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I have an onboard air compressor on my truck that pumps up my airbags. It was installed with a way to plug in an air hose and pump up tires, mattresses, tubes, etc. It works great for pumping up the airbags, but does not work very well at all to pump up anything else. If you have one, how does yours work? Anyone else have this problem? If you do, how did you fix it?
* This post was edited 01/09/09 09:49am by Tizi *
2008 Dodge Ram 2500 QC 4x4 - HEMI
2004 Northern Lite Ten-2000 CD
1998 Glastron GS 180 SF w/ Merc 150 HP
Tizi's Transformer by whazoo
BillArf
Posted: 01/09/09 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Go to Dell's website with the service tag info off the unit and you will find all your answers there..
I just had to say this! (inside joke)
dhamblet
Olympia, WA
Posted: 01/09/09 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Thats because the compressor has low CFM it doesn't have a tank. It pumps the airbags up with air directly from the compressor because airbags don't hold a lot of air anyway. If you want it to work better put in a small storage tank. The compressor for my Pacbrake has a small tank and works ok for small jobs.
2005 Dutchmen 35SRV, Pergo, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airbags, Pacbrake, Britebox, 60g aux fuel tank
04 Harley Ultra, 05 CanAM 400MAX Quad
Spending my kids inheritance
Tizi
Puyallup, WA
Posted: 01/09/09 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Haha!
Splashers3
Oakville, MD
Good Sam RV Club
Posted: 01/09/09 11:58am Link  |  Quote  |  Print  |  Notify Moderator
I wanted the same capability when I had my compressor installed in my truck recently. The installer told me that I would need a small tank to be able to inflate my tires, and when he said it would cost another $300 to do it, we both agreed that it would be easier for me to bring along my portable pancake compressor.
You need the tank, space for it, and more $$.
2008 GMC Sierra 2500HD D/A
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 350,
Blue Ox Bed Saver, TST Tire Monitor
2009 Cedar Creek Silverback, GII, 32 WRL
copter
Viagra helps a
Posted: 01/09/09 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
RIP OFF....
06 GRAYSTONE LBZ | MBRP 4" TURBO BACK | NOR*CALTRUCK 4-6 LIFT | AMP STEPS | 4300k HID'S | KMC DIESELS
06 COACHMEN ADRENALINE 314FS TOY HAULER | CLEAR LEDS | A&E POWER AWNING | ON BOARD AIR
05 HONDA 450R & HONDA 400EX
__________________________________
kaydeejay
SE Michigan, USA
Posted: 01/09/09 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
For mattresses, tubes and other "toys" you need a high volume, low pressure pump. What you have is a very low volume, high pressure pump.
An accumulator tank will help. It won't reduce the time the pump has to run, but will make a larger volume of air available in a shorter time.
I have a plug-in 12V high volume vane type air pump (not a compressor) for the low pressure stuff. Sold specifically for inflating air mattresses etc. complete with 1" adapter for the big air mattress fill valve. Mine cost me $10. (at Kmart IIRC)
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
MichDoc
Michigan
Posted: 01/09/09 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
This is absolutely correct. Here is one similar to the one I bought. You might get one cheaper if you check Bass Pro or Cabellas, or other sporting goods outlets.
