CentralCoastCampers
Central Coast, CA
I just upgraded one of my DirecTV receivers to HD. Now, every time I turn the TV/Receiver on, it takes about a minute to start and I get the "Acquiring satellite" info message and progress bar. I have also noticed that I usually have to hit the box power button again after the main power button that turns on the TV and the box. The power button light on the box is red after the first hit and I have to hit the button again to get it to go green. Is this normal on the HD boxes? None of the "standard" boxes do this, and there's picture as soon as they power up.
'05 Keystone Challenger 34 TBH 5th wheel
'05 HD Dodge 3500 DRW extended cab CTD, 4X4, 4:10 gears
Duck
Miami Lakes, Fl
Good Sam RV Club
While traveling, once I acquire the signal and finish the setup I never get the "Acquiring Information" again until I move to our next location. If you are getting a "Acquiring Satellite" notice then you might be trying to acquire a channel that is not available at your location. Usually your local channels which are spot beamed.
Don
08-FORD F350 PSD
08-Hitchhiker II 34.5 UKSBG
CentralCoastCampers
Central Coast, CA
It doesn't matter which channel the TV was last on. Once powered off, the receiver always begins at that screen. This dish is installed at the house, so it's not moving between power cycles. I haven't progressed to HD in the fiver yet.
MaverickBBD
Bellingham, Wahington, U.S.A.
No this is not normal. Did the dish get changed when the receiver got changed? Sounds like the remote has an issue with the way it was programmed. Get on the phone and get them back to fix it.
Tom & Cheryl
2005 Winnebago Journey 36G w/Cat. C-7 350 hp on Freightliner XC
1994 Jeep Cherokee Sport Toad w/ SMI brakes
Roadmaster tow bar
FMCA 397030
WIT 129107
Pesident San Juanderers
CentralCoastCampers
Central Coast, CA
Yes, got a new dish for the HD. I'll give them a call. Thanks for the info, I didn't want to call just to be told this was "normal" for the HD receivers.
Aridon
SE Florida
Good Sam RV Club
CentralCoastCampers wrote: I just upgraded one of my DirecTV receivers to HD. Now, every time I turn the TV/Receiver on, it takes about a minute to start and I get the "Acquiring satellite" info message and progress bar. I have also noticed that I usually have to hit the box power button again after the main power button that turns on the TV and the box. The power button light on the box is red after the first hit and I have to hit the button again to get it to go green. Is this normal on the HD boxes? None of the "standard" boxes do this, and there's picture as soon as they power up.
Not normal if that happens all the time. Check your signal strength it should be a minimum of 70% on all conus beams and really should be in the 90+. Your dish might just barely be getting signal causing the box to constantly drop service while off or your box itself could be defective.
2008 Newmar 4330 (Modified)
CentralCoastCampers
Central Coast, CA
UPDATE: DirecTV came out yesterday and replaced the box. It had a bad chip in it was wasn't storing the guide info once it was shut off. The new box works great. Thanks for the info.
pulsar
Lewisville, NC
Good Sam RV Club
Thank you for the update.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
gtye
Colorado
Not to get anything started here, but it's my experience that DirecTV has some quality issues, especially with their HD receivers and HD DVR's. I'm on my third HD DVR. This one works real well, only needing an occasional restart.
Gordon & Patti
2008 F-350, 6.4L. Power Stroke, CrewCab
2004 Laredo 29GS Fifth-Wheel
Be Safe!!!!!
Dead Horse Point State Park, UT
