RV.Net Open Roads Forum: Tech Issues: Solar System – Do It Yourself Info?
 > Solar System – Do It Yourself Info?
Tech Issues Related Tips
CVD
Corona, CA
Posted: 01/27/09 04:03pm Link  |  Print  |  Notify Moderator
I’m looking into a simple system (probably 40 – 50 watts to maintain the batteries when in storage). Any recommended sites for explaining the installation process? I’m most concerned about making electrical connection (i.e what is the right way to connect to the controller and to the batteries?), and how to mount the panels on the roof (I don’t want leaks after I’m done, and I don’t want the panel being blown off in Santa Ana winds).
If I decide not to tackle it myself – any recommended installers in So. Calif (preferably Inland Empire)?
Cliff
1999 Itasca 34V DP
2000 Jeep Wrangler Sport
RicJones
So. Cal.
Posted: 01/27/09 04:38pm Link  |  Print  |  Notify Moderator
I just installed 2 85 watt panels on my MH. Pretty easy, I even made my own mounts, but if I did it again I would probably buy them.
Santa Ana winds wouldn't be any worse than the wind you would have driving down the road at 70 mph.
Solatron in Victorville is a pretty good place for panels and installation.
1 800 647-6527.
If your rig is sitting in direct sunlight a 50 watt panel should keep up the battery.
Crazy Ray
Monroe,La
Posted: 01/27/09 04:56pm Link  |  Print  |  Notify Moderator
Cliff go to rvtechlibrary.com and go to solar and click. Might help you
RET ARMY , DW Donna , Summer (Furkid recently passed). Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN:14,18,20,11 LOVE CO & NM
2manytoyz
Central FL
Posted: 01/27/09 08:30pm Link  |  Print  |  Notify Moderator
They are easy to connect, and certainly a DIY project.
Here's a basic setup I put on my boat that's at a storage facility, with no power hookups: Basic Solar Setup.
I have also mounted solar panels on my roof at home. I had to slowly figure out things as I went. With such a popular topic, you'd think there would be lots of DIY websites showing the steps. I couldn't find much info, so I posted the various phases of my setup at this link.
I'm using Z-brackets to hold the 130 Watt Kyocera panel to the roof. This was designed to mount panels on RVs.
Source: http://store.solar-electric.com/unrvflmofefo.html
Here's the bracket in use on my home. Holding up nicely to rain/wind here in FL.
There are proper sealants at RV suppliers for the type of roof material you have on your RV. I'm using 100% silicone on my home roof.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
2010 Ford F-150 FX4 -w- Max Tow Package
Yamaha EF2400iS
http://www.2manytoyz.com/
Bill&Pam
If its winter - probably AZ, otherwise - who knows
Posted: 01/27/09 09:31pm Link  |  Print  |  Notify Moderator
I did this install myself. Bought: All hardware at Home Depot; Solar panels from a Scottsdale, AZ dealer; Fused disconnect from an electrical supply; Controller and Tri-metric meter from Backwoods Solar.
Bill & Pam, Somewhere, USA
South Dakota domicile
2007 Monaco Diplomat 40 SKQ
2005 Chevy Colorado TOAD w/M&G Brake system
2006 Honda Rancher ATV
