RV.Net Open Roads Forum: Technology Corner: LCD TV
Technology Corner Related Tips
jarbra15
El Paso, Texas U.S.A
Good Sam RV Club
Posted: 01/30/09 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I currently have a tube tv in my 5th. wheel and I get a lot of glare on the screen during the day. Can anyone tell me if an LCD TV screen is any better? Are there any specific brands or models that have less glare than others?
Brad & Carol
2001 Dodge 2500,Quad Cab, LB,5.9CTD,Auto,3.54
2004 Cedar Creek Silverback LRLFS
15K Lil Rocker hitch
Tekonsha-Prodigy Brake Controller
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 01/30/09 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
jarbra15,
Just a note: The format error in your signature is caused by the "end blue text" tag.
You can remove the tag on your preferences page
    My Forums -> My Preferences.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
fullautodave
currently in Rogers Arkansas
Good Sam RV Club
Posted: 01/30/09 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have three of them in my trailer, 2 Samsungs and an RCA and neither one has any glare.
2009 Mobile Suites TKSB3
2008 Ford F-450 Superduty
2009 Jeep Rubicon toad
1999 Bigfoot C1011FR
Davydd
Minnesota
Posted: 01/30/09 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Direct bright sun can overpower the color of a matt finish LCD but you won't get the mirror reflections like you get off a glass CRT. There are some glass like LCD screens that will mirror reflect. I'm thinking of Samsung but only in the large 42"+ screens.
Davydd
2005 Pleasure-Way Plateau Sprinter B Camper Van
Davydd is the Welsh spelling for David with an English twist using a v instead of an f.
See Our Pleasure-Way and my pork tenderloin sandwiches
Visited states in an RV
John3872
Iowa
Posted: 01/31/09 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I agree. I switched out my tube and am much happier with the LCD.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
DrawTite Brake Controller
SHADOWMCPD
NYC
Posted: 01/31/09 08:24am Link  |  Quote  |  Print  |  Notify Moderator
jarbra15 wrote:
....LCD TV screen is any better? Are there any specific brands or models that have less glare than others?
Depending on the resolution of the replacement TV you should see a much better picture since you will be seeing more lines of information across the screen. (720P/1080i/1080P)
this will in essence give you a better picture but what you really want to do for any picture source is to control the light that is coming into the viewing area as this will do more for perceived picture clarity (and eliminate glare)than anything else. (there is a reason why movies are projected in a dark room)
Good quality cables will also make for a much richer picture and more enjoyment as you will see richer colors, sharper images and darker black levels with less noise ( Picture noise is different than audio noise)
Angle of view will also have an effect on how the image is perceived so consider where and how high (or low) the location of the TV will be from the viewing area.
A combination of the above should give you an opportunity to improve your overall TV/Movie watching experience.
While you are limited with how you can manipulate a tube TV, a flat screen will give you much more flexibility since you are not only reducing the bulk of the set but the weight as well.
Keep in mind that flat screen sets can also be mounted,* so look around and see if there is somewhere else in the RV where the amount of light to reach the screen can be reduced or eliminated and the comfort viewing angle can be improved
* keep in mind the weight of the TV and the mount as RV bulkheads are not as solid as in a stick home but it can still be done. (Even suspending a mount from under a cabinet is a possibility)
Good luck and let us know everything turns out.
Fred S
NYC
balvert
Windsor, Ontario
Posted: 01/31/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
My old glass tube TV was totally useless on a sunny afternoon with curtains open. The LCD is much better as the screen has a mat finish.
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
RJsfishin
Winston Or.
Posted: 02/01/09 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Our 15" LCD has a glare,...or black out problem in bright daylite, except when viewing in a near straight on view, then it is a good bright picture.
Maybe the quality of the LCD makes a difference. Ours is a Audiovox 5 yr old analog LCD running on 12 volt.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
