Beddows
Abbotsford, Canada
There is absolutely no problem with using a SR/SB off the truck on its jacks. Just lower it down close to the ground. My previous camper was quite wobbly. Snowbird campers have very well anchored brackets, they use sikaflex under the brackets not the grey putty tape. The owner of the company once demonstrated how strong it is by removing all the bolts from the brackets & supporting it with the adhesive only. I can't even get mine to wobble a little bit using it off the truck.
saleenguy
Kamloops B.C.
BlueStilly wrote: Off topic I know, but it's also a good idea to put a good quality bed mat in your truck for the camper to sit on. Helps keep the camper from shifting around. Even with the tie downs they can move around a bit.
I am going to get a spray in box liner is that enough, or do I need a mat to?
BoilerEE,
thanks for the link to the stabilizing brackets, those would be very easy for me to make in the shop.
If I find it sways, I will just fab some up myself.
Thanks again everyone.
Traded my travel trailer for a camper.
Now I have to learn all the tricks to campers, I already knew for travel trailers.
FreeLanceing
Grand Haven Mi
I would definetly spend the 70 bucks for the mat. It will cushion the camper and prevent any movement.
BlueStilly
Stanwood, Washington
saleenguy:
I think most here would agree that having a spray in liner is a great way to go. I have had 2 trucks with Linex spray in liner and have had no problems and would reccomend the product highly. I'm sure others have had great luck with Rhino. Kind of a Ford, Chevy or Dodge thing. You find what works well for you and then defend to the death why you are right and the other guy is wrong . I also think most here would get on board with a mat over the liner. I got mine from Carquest for about $70.00. It's about 3/8" to a 1/2" thick, good quality in my opinion, and is cut out to fit my Dodge. And they also are made to fit those other 2 brands as well .
Good luck and keep asking questions, and we in turn will rant, rave and hash it out amoug ourselves untill ya get it right.....
saleenguy
Kamloops B.C.
BlueStilly wrote: saleenguy:
I bleed blue, I am that much of a ford guy.
And yes, I am getting a rhino liner sprayed in.
I will look into a bed mat as well.
I see no need for a bed mat or bed liner in a chevy or dodge though.....Just how would the box get damaged in the shop.....LMAO
saleenguy
Kamloops B.C.
The above post was a joke for anyone that missed it.
BlueStilly
saleenguy wrote: The above post was a joke for anyone that missed it.
Looks like you will fit in around here nicely for a trailer guy with a Ford........
iwon415
Northern California
A bed mat is a must, and with a quality mat you really wouldn't need a liner, unless its for work when the camper is off. Otherwise you are just adding unnecessary cost. I went with a mat only after advice I got here and never looked back.
TimH
BradW
Flat Rock, Alabama
FreeLanceing wrote: I would definetly spend the 70 bucks for the mat. It will cushion the camper and prevent any movement.
Ditto. The bed mat is there to reduce the movement of the camper in the truck bed. If the camper slides around, it puts a LOT of strain on the tied own system. It does help protect the bed, but it's mainly there to encrease the coefficent of friction between the camper and the truck bed/Rhino Liner.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
blackstx
Pittsburgh, PA
Look for blem bedmats on ebay. I picked up a blem bedmat for a Chevy and put it into my Dodge. I had to trim the two front corners for it to fit. And the blem part????? I really can't find anything wrong with it. I think I paid $35 shipped to my door.
2006 Dodge CC, LB 610 Cummins 6 Speed, Hellwig rear sway bar, rear air bags, 4" Superlift lift, 315X75X17 Mikey Tompson Baja ATS's on factory rims.
2004 Bigfoot 15C9.5FS nicely equipped
