RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Campfire Pot Hanger/Grill/Utencil Holder
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Campfire Pot Hanger/Grill/Utencil Holder
Camp Cooks and Connoisseurs Related Tips
sdagro
Independence,LA
Posted: 02/04/09 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Last month while camping in Mississippi I saw a setup on a campfire that I just have to make/have. It consist of a 1-1 1/4 5ft pipe as the vertical pole. Off of that is a 3/4 or so that extends about 3 ft with an eye on it with a chain to hang your cast iron pot over the fire. Below that is another arm(adjustable)with a grate for grilling. What is really neat is they had at the top of the vertical shaft, an inverted 2" hitch ball with a solid 10-12" rod welded to top & bottom and slipped it into the top of the vertical as a driver. They would raise the ball up and use it as a driver to set-up the cooking rack. Anyone ever seen one of these and/or have any pics. I guess I should have gotten a better look or had a Kodak Moment. Thanks in advance for your replies. Steve A. Dagro
RlphKnndy496
Sedro-Woolley , WA.
Good Sam RV Club
Posted: 02/04/09 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
you need to sketch a pic....i'm confused?
heavyputer
Ontario, Canada
Posted: 02/05/09 05:32am Link  |  Quote  |  Print  |  Notify Moderator
Check Cabella's catalogue. They have them. (or go to "cabellas.com"
If at first you don't succeed, skydiving is not for you!!!
Heavyputer, 1 DW,
2008 F150 4X4, 5.4l, 24 valve
2008 Dutch Star, 400 Cummins, 6 Sp Allison
MrSeven21
Cape Cod MA
Posted: 02/05/09 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you need to bust out the welder and some scrape pipe and get to work. That sounds home made or as we like to say CUSTOM.
2004 F-250 Crewcab 6.0 Diesel 4x4
2009 Rockwood Roo
tom_kat
way upstate new york/lake george area
Posted: 02/05/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
sounds like homemade to me also.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
85Eagle
Louisville, KY
Good Sam RV Club
Posted: 02/05/09 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
If they are driving the pipe into the ground this could be an accident looking to happen. Do you know where the underground utilities are in a campground. For instance in Florida some places they are only 6 to 10" below ground.
85Eagle
Conversion Coach
Louisville, KY
Beacher
Long Beach, CA
Posted: 02/05/09 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
There are countless homemade versions, (the one with the hitch ball), however, it's a common design. Here is one with a horseshoe instead of a hitch ball for the impact driver. These have a place to hang pots.
* This post was edited 02/05/09 04:20pm by Beacher *
sdagro
Independence,LA
Posted: 02/05/09 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Good point. We do check all of that out 1st and even ask the park ranger/attendant prior to driving post. Steve
sdagro
Independence,LA
Posted: 02/09/09 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Keep the ideas coming. We're getting closer. Steve
symbasden
WI
Posted: 02/12/09 10:09am Link  |  Quote  |  Print  |  Notify Moderator
If the fire ring is over top of a water pipe that is only 6" in the ground that is a bigger problem than driving a stake into it. Same goes for electricity lines. We routinely have a fire for 8 hours, in 8 hours the heat from the fire would easily melt the insulation on the wires and a lot of water/sewer pipes at that depth
Jeff
2009 Rockwood Signature Ultra Light 8317SS
2004 Dodge Ram 1500 QC LB Hemi
DW Kelly and DD
