RV.Net Open Roads Forum: Truck Campers: Truck Camper Shelter/Car Port
 > Truck Camper Shelter/Car Port
18seeds
Denver
Posted: 02/04/09 11:07pm Link  |  Print  |  Notify Moderator
any suggestions on a shelter system for my truck camper. Something not too ugly is preferred
2006 Dodge Ram 2500 Cummins Turbo DIESEL
trails2004
Outside
Posted: 02/05/09 05:06am Link  |  Print  |  Notify Moderator
I will be watching this one- I could give you a link- but I'll bet you have already done a google search
~DJ~
Boise, Idaho
Posted: 02/05/09 05:31am Link  |  Print  |  Notify Moderator
I have been kicking this idea around for some time. 12'X20' standard metal carport.
Now saw the legs off
Install electric camper jacks on all 4 corners. The middle legs would be made form two sizes to fit one inside the other for a telescoping capability and drill some pin holes at different heights.
Back the cmaper in under the 12' clearance and park it. Or unload it and lower the carport down on it.
I'm still in the fantasy stages.
2011 F250 Super Cab Lariat 6.2 373 FX4 Short Box 4" BDS, 35" Toyos, TorkLift, 16.5K Warn, Locked & Loaded
2007 SunLite Pop Up
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
JANE CALL HOME
1 800 HANOI
Spott
SE Michigan
Posted: 02/05/09 06:04am Link  |  Print  |  Notify Moderator
Thats a lot of work, when all you really need is a Stable Lift.
Me - Kim - Spot
FreeLanceing
Grand Haven Mi
Posted: 02/05/09 07:50am Link  |  Print  |  Notify Moderator
I've been toying with the the idea of a lean to off the side of a story and half garage. Everyone says it would look to addon attached to the already 3 stall garage. It already looks like a garage with a house attached to it. It would be a nice set up the height works out, power right there.
silversand
Montreal
Posted: 02/05/09 08:00am Link  |  Print  |  Notify Moderator
...if the building itself and lean-to design are structurally sound together (an engineer can verify this), then the lean-to could be made to look architecturally appealing, no problem.
A word of warning, however: one of our contractors had (yes, past tense) a very expensive lean-to attached to a steel commercial building, with the lean-to, it's attachment to building and ground rated for 105 MPH momentary wind gusts; a month ago, the entire structure (only 2-years old!) tore out of the ground, and ripped the side of the steel building clean off in a ~~~115 MPH momentary wind burst during a super-storm (in the valley) ! What a hell of a mess.
Caveat: open ended buildings can be very functional if they are located in areas where winds will not exceed the car-port design specs...
Good luck,
Silver-
Silver
LanceCamper845
Pocono Mountains, PA
Posted: 02/05/09 08:01am Link  |  Print  |  Notify Moderator
This is what I have. It has been working great for the past 5 years. Truck Camper still looks brand new and it keeps the rain, snow and sun off the roof. Colors match the house.
2008 Ford F-250 Crew-Cab w/ Camper Package
6.8L V-10 / 5 Speed TorqShift / 4.10 Rear
Ride- Rites / Stable- Loads / TorkLift Tie Downs / Fast Guns
2011 Lance 830
bigfootford
Fair Oaks, California
Posted: 02/05/09 08:07am Link  |  Print  |  Notify Moderator
I've used this company two times....You order it and installation is included. If you need a certified structure they have those with plans so you can get your permits. You build it the way you want.
Carolina Carports.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
thundercloud
Durango, CO
Posted: 02/05/09 10:03am Link  |  Print  |  Notify Moderator
I added a carport to the side of the house and garage last spring. It worked great for the Outfitter we use to have, but the new Bigfoot I have to drop it off prior to the carport and place it on a camper dolly then push it back in its storage place. So far not a big deal. I could not have made the carport any taller for various reasons but I think it turned out pretty nice. I am able to get my truck under it too (14'x45').
Happy TC'N,
Dave
____________________________________________
2006 Dodge Ram 3500 MegaCab 4x4 CTD 6-speed
2008 Bigfoot 25C9.4SB, Xantrex XADC 60, AM Solar 200 watt SunRunner system
middlecalf
Sweet, ID
Posted: 02/05/09 10:15am Link  |  Print  |  Notify Moderator
I put one of these ( http://www.shelterlogic.com/ ) up this summer (14.5 oz fabric), so far so good. Covered on both ends (one end has a roll up door) because of dust issues with nearby dirt road. The door opening height required to back in with the camper on the truck set the overall height of the shelter, which is 14' at the crown, more than enough clearance when jacking camper to load/remove. It's tied down in 8 places with 36" tiedowns.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
