RV.Net Open Roads Forum: Technology Corner: WiFi Signal Strength
 > WiFi Signal Strength
Technology Corner Related Tips
qtla9111
Monterrey, Mexico
Posted: 02/07/09 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just returning from a trip to San Antonio where I noticed that staying at my neighbor's house about six feet from his router, the signal in my rv was the best ever. However, in the house with my laptop the signal made it very difficult to watch YouTube, Yahoo News video, etc.
I have the same problem at home and am wondering is it my router, or is it the signal I am receiving from my provider?
As you know from past questions, I am not tech savvy so please understand. My signal, as it is showing at the bottom of my laptop right now says, "excellent" at 54,0 mpbs. Yet watching a YouTube video I need to keep bumping it to move and eventually it just stops.
So is it my laptop, signal or my router? The router is less than 18 ft from where I am right now.
Thanks for you knowledge and experience.
1998 Nissan Pathfinder
2004 Shadow Cruiser 18ft.
Living and Boondocking Mexico
2oldman
Indio CA
Posted: 02/07/09 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
That number means nothing.. but it's not your signal strength anyway. It's simply the maximum best connection speed you could ever achieve to your router. 54M would put to shame ANY internet connection if you could actually achieve that on the internet as measured by any number of online sites.
For your connection strength, look at the number of little green bars either in the tray icon or connection properties. Wifi is pretty directional.. you may need an external antenna or move around a bit. And by external antenna I mean a little dongle on a USB cord, made by Linksys.
It has nothing to do with your ISP.
qtla9111
Monterrey, Mexico
Posted: 02/07/09 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick response. Even if I move next the the router, the problem is the same
2oldman
Indio CA
Posted: 02/07/09 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you conclude your actual wifi signal to the router is ok, then it may be your ISP that's slowing you down. Take the wifi out of the problem and plug directly to the router.
qtla9111
Monterrey, Mexico
Posted: 02/07/09 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
You're good! I connected directly to the router and the videos download super fast.
So not to sound tonto, but does that mean my wifi, brand Belkin, is not very good and I should change it out?
Thanks very much for the help!!!
Alfred622
Rochester, MN
Posted: 02/07/09 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
try resetting the router. Just unplug it, wait a full 3 minutes, and plug it back in. I bet that will help.
Alfred
2005 Sightseer with Workhorse
Map below shows states where we actually camped.....
Wherever I happen to park
Posted: 02/07/09 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
There are many things that can affect Wi-Fi signals. one is multi-path interference
Another is strength. Alas, Excellent should mean you can watch you-Tube with no problems (I can)
But here is something you might wish to check out http://www.dnsoft.be/detailinfo/wifisistr.txt
Now this is just the info page.. it's the product (WiFiSiSTR) you want. (you will have to navigate to it from there)
IT's a signal strength meter
-60 DB I can watch You Tube -75,, I can't
My2500HDTruck
Contra Costa County
Posted: 02/07/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Here is another possibility - Is your laptop relatively new? If so, it may have a newer wifi card, like 802.11n. A little older laptop/router is probably 802.11g (which has a max throughput speed of 54 mbit.) The 802.11n is a newer wireless standard and have a speed of 150 mbit. Much-much faster. I just swapped out my older 802.11g router and replaced it with a 802.11n router and WOW. I can watch streaming video like I was connected directly. If your laptop is 802.11n ready, it can detect either the 802.11n or g signal and configure automatically.
2004 Silverado 2500HD: LT, Crew Cab, Duramax/Allison, 4x4
2000 Coleman Timberlake Popup
mikew9
Posted: 02/07/09 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that the wifi channel that you are using is not also being used by another router within range. e.g. Where I am currently sitting I can see 4 wifi broadcasts all using channel 6! Thus if I were smart I'd pick some other channel to avoid having my signal stepped on.
Mike in Texas
