RV.Net Open Roads Forum: Technology Corner: Digital TV Converter Box
 > Digital TV Converter Box
Technology Corner Related Tips
Dandy
NorthEast
Posted: 02/09/09 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Is the box required with the newer TV's. I am not sure how it would work with the Concertone Garbage.
Post moved from TT Forum to Technology Forum
Moderator - TT Forum
* This post was edited 02/09/09 11:40am by an administrator/moderator *
Chevy 1/2 Ton Crew Z71 / 3.73 / 5.3L
Rockwood 8317 SS (Yes, it's a 1/2 ton pulling it)
Reese WD System with HP Dual Cam
Primus Brake Controller
Factory Receiver Hitch
McKesh Mirrors
Bucky Badger
Madison, WI
Posted: 02/09/09 06:08am Link  |  Quote  |  Print  |  Notify Moderator
In short.....If you are trying to use over the air antenna for the TV and the TV does not have a digital tuner you do need one, If you are using sat or cable you do not need one.
There is a FAQ here and this gets discussed all the time in the thechnology area http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22125103.cfm
* This post was edited 02/09/09 06:30am by Bucky Badger *
Fred & Jodie, dogs, Zoey & Bella
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
http://banners.wunderground.com/weathersticker/gizmotimetempbig/language/www/US/CA/Carlsbad.gif
Rallies/Gatherings
IL
WI
Dandy
NorthEast
Posted: 02/09/09 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know if the Rockwood TV's have built-in digital converters?
Bucky Badger
Madison, WI
Posted: 02/09/09 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Is it a flat panel or a tube? If it's a tube no way it's digital. Scan for channels and see if you pick up the digital ones. They will be something like 15.2, 21.1, 47.1. If it only picks up 15, 21, 47 thoes are not digital channels. The front of the tv or the owners manual should tell you if you have a digital tuner.
What do I need to do?
If you have digital TV(s), you do not have to do anything. A TV is digital if it has a digital tuner (ATSC). Digital TVs should have a label; for example, "Digital Tuner." Note: "Digital Ready" does not mean it has a digital tuner.
One way to tell if a TV is digital is to look at the remote control. A remote for a digital TV will have a period '.' or a dash '-' with the numbers so that one can enter 7.1, 7.2 (7-1, 7-2) etc.
ddreisbach
Kemah, TX
Good Sam RV Club
Posted: 02/09/09 06:46am Link  |  Quote  |  Print  |  Notify Moderator
You could check the on-screen input menu to see if digital or DTV is offered. My Vizio remote has buttons for NTSC (analog) and Digital. The set may have separate inputs for analog and digital. There are many ways to tell.
mockybird
Mocksville,NC
Good Sam RV Club
Posted: 02/09/09 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Most newer tv's are already set up for digital. No need to get a converter box even with TT antanae. You should have an option to use digital from your remote or menu option as mentioned above.
Gary
Major Dad
San Antonio TX
Posted: 02/09/09 08:18am Link  |  Quote  |  Print  |  Notify Moderator
The flat-panel Venturer TV (that replaced the original Concertone piece of garbage)in my 2008 Rockwood 8272S receives DTV without a converter box. If you are still using a Concertone TV that hasn't yet died, it may very well die soon. I don't know if I'd get a converter box for a TV that is about to die.
On the other hand, all the RF TV stations are now transmitting in digital as well as analog. If you selected the autotune mode, you may have already been receiving DTV without realizing it.
2008 Rockwood 8272S
2004 Nissan Armada SE 4X4
Equalizer Hitch
redwake
Visalia, CA
Good Sam RV Club
Posted: 02/09/09 10:10am Link  |  Quote  |  Print  |  Notify Moderator
i have a tube tv that picks up dtv, bought it at wally right after i got my tt trutech brand.
it has an analog tuner and a digital tuner... however i've heard that if you spend a little more the better tv's will pick up the name of the shows so you have a tv guide built into the tv like on cable or satalite.
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
amxpress
Clayton, NC
Good Sam RV Club
Posted: 02/09/09 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Concertone AM/FM/DVD/CD/TV tuner (i.e.ZX-500 & 550) is not a digital TV receiver. The only thing digital about it is the DVD player.
This, according to Concertone.
A digital converter box will work with it because you will be hooking into the antenna.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
