RV.Net Open Roads Forum: Tech Issues: Fridge problem in Mexico
 > Fridge problem in Mexico
Tech Issues Related Tips
mexicokid
Vancouver Island, Canada
Posted: 02/09/09 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Anyone have any advice...I am in the boonies in Mexico with my Aspect 23 foot class C the fridge is a Norcold N611...I had problems and drained my house batteries and then the fridge went on the blink....the flashing light sequence and the answer in the manual is to to check everything then reset, I did that but nothing now the manual says after 2nd reset this is not owner serviceable, see your dealer,,any advice? Thanks
jmanatee
Willington, CT
Good Sam RV Club
Posted: 02/09/09 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
This is the procedure I have on file.... I am not sure it works I just have it on file
1. Turn off refrigerator
2. Disconnect the following wires on the power board in the black plastic box.
IN THE ORDER SHOWN.
a) 12VDC. Positive and negative wires
b) AC power cord.
c) Solenoid gas valve wires.
d) Spark/sense electrode assembly wire
3. Remove the black power board cover.
4. Reconnect the wires in the reverse order you removed them in above step number 2.
a) Spark/sense electrode assembly wire
b) Solenoid gas valve wires.
c) AC power cord.
d) 12VDC. Positive and negative wires
5. Turn on the refrigerator.
6.Locate pin 15 on the wire harness 16 pin connector (P1) Pin 15 is the socket to the
right of the white/violet wire. Looking at the socket on the board it will be the
SECOND PIN over FROM LEFT TO RIGHT on the TOP row.
NOTE: do NOT remove the connector! Pin 15 has no wire in it...just stick your jumper
into that hole making sure you actually make contact with the internal pin. sometimes
this is difficult unless you use solid wire vice stranded.
7. Using an insulated jumper wire short pin 15 to the power board ground lug for 10-15
seconds. You will hear a click sound indicating that it has reset.
8.Turn OFF the refrigerator.
9. Turn ON refrigerator to verify the "no co" has cleared. If not perform the reset again.
10. Turn OFF the refrigerator.
11. Disconnect the wires again in the following order
b) AC power cord.
12. Install the power board black plastic cover.
13. reconnect the wires in reverse from step 11.
c) AC power cord.
14. Place refrigerator in service.
Thats all there is to it!
Jon
Our RV Web Site | Our New RV
Our Solar Install | Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
2008 Monaco Cayman XL 38PBD
MELM
GA
Posted: 02/09/09 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'll supplement Jon's post. Below is a link to the Service Manual and to instructions on resetting the board.
Go to this page: Service Manuals. Scroll down the page to the "Norcold N Series manual. Covers N61X, N62X, N64X" and download it. Just below it are two more documents on the Reset Procedure. Both have pictures of the connector where the jumper connects.
The Service Manual has more details on the fault codes - see the manual page 8 for the N61X models. Page 21 has the reset procedure, too.
Other members have reported getting their reefers back in service using the reset procedure. If you aren't successful, maybe some of the other info in the service manual will help you isolate the problem.
Hopefully, your board just got "confused" with the 12 volt power issue.
Mel
mexicokid
Posted: 02/09/09 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for taking the time to explain all of this, will try in the morning and keep you informed again this board and it's members are the best, thanks Les
Kirk
Livingston, Texas.
Posted: 02/10/09 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
mexicokid,
Any luck yet? Let us know as there may be more help. Do you have an error code from the display?
Good travelin! ........Kirk
Professional Volunteer
www.adventure.1tree.net
mexicokid
Posted: 02/11/09 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
THANK YOU!!!!! tOOK ABOUT 8 TRIES BUT WITH HELP MANAGED TO GET IT RE STARTED....This forum just coninues to amazeme, thank you so much Les
wilbur267
Posted: 03/20/09 08:08am Link  |  Quote  |  Print  |  Notify Moderator
jmanatee --- THANK YOU THANK YOU THANK YOU
I tried the reset from the manual and the one I had did not have any sequence of events. Your post saved me a 100 mile trip to get warrenty work done.
