RV.Net Open Roads Forum: Technology Corner: Winegard 'Wingman" comparison results
 > Winegard 'Wingman" comparison results
Page of 6
SCVJeff
Santa Clarita, CA.
Posted: 02/15/09 12:47am Link  |  Print  |  Notify Moderator
Armed with a Spectrum Analyzer I did some comparison tests in the coach on the Winegard Sensar "Batwing" antenna on UHF only, with and without the addition of the new Winegard "Wingman" snap-in 3 element director they just came out with. I saw it in Quartzsite and it got me curious.
Those familiar with reading these images will note that there is definitely a marked increase in gain as well as improved side and rear rejection as would be expected. One will also note that as the antenna swings toward 170 degrees that several new carriers appear from Ventura, 50 miles to the West. There are one or two LP's scattered in the mix between the two markets as well. As noted, this test was limited to the UHF spectrum only since the additional elements will have no affect on VHF whatsoever.
Those that can't read these, the bottom line is that the antenna does pick up about 3db which is about what was expected. When you're on the hairy edge of a DTV signal, that 3db will make all the difference. For $20, I'll keep it.
Looking at the entire UHF Spectrum (both Analog and Digital carriers) on Mt. Wilson (Target) aprox. 30 miles downrange from Santa Clarita (and extremely multipath'ed).
As above with the addition of the Wingman pointed at Target
Antenna pointed 45 degrees East of Target.
Antenna w/ Wingman pointed 45 degrees East of target.
Antenna pointed 90 degrees East of Target
Antenna w/ Wingman pointed 90 degrees East of Target.
Antenna pointed 170 degrees East of Target (Mechanical stop @ 180).
Antenna w/ Wingman 170 degrees East of Target.
Antenna pointed 45 degrees West of Target.
Antenna w/Wingman pointed 45 degrees West of Target.
Antenna pointed 90 degrees West of Target.
Antenna w/Wingman pointed 90 degrees West of Target.
(edit: fixed formatting)
* This post was edited 02/15/09 01:04pm by SCVJeff *
Jeff - WA6EQU
bounder35
Cincinnati, Ohio 45238
Posted: 02/15/09 08:30am Link  |  Print  |  Notify Moderator
Great info. Fotr the price you can"t go wrong.
Nick & Patti
2011 Fleetwood Discovery 40X
Toad 2004 Hyundai Elantra
FMCA # 399505
Learjet
Louisiana
Posted: 02/15/09 09:21am Link  |  Print  |  Notify Moderator
thanks for the test !!!!!
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
MrWizard
Traveling
Posted: 02/15/09 10:55am Link  |  Print  |  Notify Moderator
thanks for the test results,
now how about an subjective difference, does the wingman let you watch the ventura station, that can't be seen without it ?
when watching the locals from mount wilson is their less picture freeze with the wingman than without.
Radiate The Happy
1997 F53 Bounder 36s
SCVJeff
Santa Clarita, CA.
Posted: 02/15/09 12:56pm Link  |  Print  |  Notify Moderator
Everything from Wilson is too strong out here off the 5 & 126. It's a funny path that's only a few miles wide, after that Wilson falls off 40db+ anywhere else in SVC. Maybe Ventura, but I don't know how many on-off cycles those plastic rivets will stand. I own several really nice HP lab quality attenuators, but all are 50ohm [emoticon]
MK 82
South Florida
Posted: 02/20/09 08:37pm Link  |  Print  |  Notify Moderator
Finally a meaningful test.
2007 Presidio 39D
Mercedes MBE926
2006 Wrangler Toad
CROSSBOLT
Whiteville, TN USA
Posted: 02/21/09 05:06am Link  |  Print  |  Notify Moderator
Great pix! Good information! Thanx!
Karl
Karl
fpresto
Maryland
Posted: 02/21/09 06:10am Link  |  Print  |  Notify Moderator
Thanks for the actual testing. I really get tired of people hooking it up seeing no significent gains and then slaming the product. As your results indicates it gives about 3db of gain. Is that going to get a station from 100 miles away? No. If you have a station that is blocking or breaking up will it help? Yes.
USN Retired
2016 Tiffin Allegro 32 SA
mikestock
Vestavia Hills, AL, USA
Posted: 02/21/09 08:01am Link  |  Print  |  Notify Moderator
Where did you fond it for $20? Every place I've seen it was $30 plus shipping.
J Walker
Oakton, Va
Posted: 02/21/09 08:03am Link  |  Print  |  Notify Moderator
I greatly appreciate Jeff's post and intend to get the booster. I fully expect we will need it and I surely don't wish to replace my batwing until I am forced to do so.
Jim Walker
2014 Thor Palazzo 33.2, 6.7 Cummins, 2100 Allison
2009 Malibu
Page of 6
