RV.Net Open Roads Forum: Toy Haulers: Keystone Fuzion generator exhaust
Search only in Toy Haulers
 > Keystone Fuzion generator exhaust
Toy Haulers Related Tips
smithrock
Long Beach, CA.
Posted: 03/01/09 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Bad design, makes you wonder how well they think these things out!
5O'clock
Northern California
Posted: 03/03/09 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Rerouting the exhaust is simple and takes about 20 minutes. A little longer if have access to a 1 1/4 in pipe bender and want to get a little fancier.
Get under the coach and loosen the two nuts on the clamp where the exhaust pipe mounts to the genny.
Remove the hanger supports.
Spin the exhaust pipe around to the other side so that it comes out between the BR and LR slides.
Relocate the original hanger brackets and attach the pipe. Tighen clamp bolts
Cut off excess pipe.
Done.
For added safety, make yourself a genturi for around 25-30 bucks.
Genny fumes and noise is now on the other side.
I did this to my 08 Raptor.
01 Dodge Ram 2500 4x4 CTD, Edge EZ, BD TC/VB Exhaust Brake, Autoloc,Pressureloc
08 Raptor 3612DS, Pullrite SuperGlide
05 Polaris Predator 500 & 08 Polaris Rzr
85 Harley FXST
"too many weekends.. Not enough beer"
5O'clock
Northern California
Posted: 03/03/09 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
One more thing. I started first with the home made genturi on the awning side but still found the exhaust drone annoying. So I spun it to the other side.
You can find some easiy instruction to build your own genturi like the one in Y-Guy's pic. They are easy, cheap and work great. For easier storage, I started with a piece of pipe with the molded in coupler (like in Y-Guy's pic). I cut the pipe in half to make to 5' sections for easier storage. I mounted the flat bar and 90 elbow to a non coupler end. I use the molded in coupler to put the pipe back together when in use to extend above the roof.
