RV.Net Open Roads Forum: Class A Motorhomes: Burning propane when moving
 > Burning propane when moving
Page of 6
mikey52
Marana, Arizona
Good Sam RV Club
Posted: 02/24/09 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Another who always has the fridge on propane when on the road.
2008 Gulfstream Bounty Hunter Class A Toyhauler
2001 Harley Davidson FXDWG
2007 Harley Davidson FLHTCU
Deen
Vancouver, WA
Posted: 02/24/09 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Roadapple wrote:
I understand it is not wise to run refig on propane when moving. Can I run the furnace when moving in cold weather safely? Hot water heater?
Class A
Why isn't it "wise to run refrig on propane when moving"?
The propane system in an RV is designed, built, tested and certified to be run while in motion so we do, but then I only have 52 years RV'ing experience to back this up.
nolra
Houston
Posted: 02/24/09 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Dealer told me to run the fridge on propane while towing.
03 Dodge 2500 Cummins SB Quad (ATTA 45g aux. fuel tank, Dr. Performance module, 4" MBRP, Ride-Rite)
08 Cougar 276RLS with 16" BFG E rated LT's
5th AirBorne pin box
SuperGlide hitch
Photo gallery
urmine351
fort smith, arkansas
Good Sam RV Club
Posted: 02/24/09 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I run them all, including my propane gen set..
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins. and Max, teacup yorkie
FMCA # F374886
D & M
Laurel, MD
Good Sam RV Club
Posted: 02/24/09 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Run the furnace and the reefer - No worries.
Dave
Mary, the world's best wife (1951-2009)
Isabel & Buddy (the Bostons)
2005 Itasca Suncruiser 35A
Don't wait until its too late.
tallyo
Fort Myers,Florida
Posted: 02/24/09 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure there are "NO WORRIES"..
For me the most obvious one is if the propane is on while refueling and before anyone says their propane is on the opposite side of the fuel fill, how about if someone else pulls in beside you and causes a problem?
What if there is a collision? Why do you think certain tunnels/ bridges require propane to be off?
If the refrigerator door is kept closed while traveling; the stuff inside is just fine.
Heat is another issue but my MH can heat the entire inside from the engine.
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
sepisllib
Cresco, Iowa
Good Sam RV Club
Posted: 02/24/09 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Class A
Ron - know you are a new member and full of questions and all, but to be realistic give some thought to this.
Is it ok to burn gasoline while driving down the road?
Is it ok to burn diesel fuel while driving down the road?
Is it ok to flip your "bic" lighter while driving down the road?
Is it ok to strike your zippo lighter while driving down the road?
If the answer to the above questions is "yes" - then I would ask you; what is the difference between the above and propane?
Honestly though - the appliances are designed and built for a specific purpose and are safe enough to use. The only "wild card" in this is us humans - we can screw up anything and make them "unsafe".
Enjoy your rig and travels ----
God Bless
Bill
Bill W. Trammell
Wife - Judy
2001 Monaco Dynasty Chancellor
2008 Malibu 2LT toad
Nascarcruzin
Home is where the RV is parked.
Posted: 02/24/09 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Sully2 wrote:
Add me to one that also runs the reefer on LP when traveling...
Same here.
Ronnie & Rebecca
Check out our adventures:
Travel Journal Enter the password - 12345
2008 Alaskan adventure
2009 Northeast coast and Canadian Maritimes
1999 Holiday Rambler Imperial 40WDS
FMCA #388387
ernestfortier
Palmdale, Calif.
Good Sam RV Club
Posted: 02/24/09 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
If there is a collision, you still have the propane tanks onboard. If there were as many worries as you think then why would you not leave the propane tanks home? The propane tanks and use of propane is no more hazardous than the gas tank and using the gasoline while travelling down the road. The propane is probaly safer than the gasoline as the propane tanks are better built and have safety shutoffs built in them. Yout gasoline tank has no such safety items.
I always run with the propane on. I shut the propane off when fueling and on the West coast we don't have any tunnels to worry about. The main concern with tunnels is that they are usually lower than any surrounding land and propane whe vented will go to the lowest point being heavier than air and if ignited in a tunnel it could cause an explosion, which would also be almost the same danger if you had a gas tank rupture in the same tunnel.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Good Sam RV Club
Posted: 02/24/09 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Add another to the list.
Page of 6
