RV.Net Open Roads Forum: Truck Campers: Headlights too high. Are airbags the solution?
 > Headlights too high. Are airbags the solution?
Truck Campers Related Tips
Raften
Northern Calfornia
Posted: 02/25/09 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Air bags can solve the problem but I would try aiming the lamps down first unless you are set on getting bags. My lights are aimed as low as they can go and I just leave them that way. Lights are very bright so that is no problem.
* This post was edited 02/25/09 06:10pm by Raften *
camp4
SF Bay area
Posted: 02/25/09 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have the firestone airbags, but I also turned my headlights down a bit.Works great with camper on or off.
2004F3504x4 Crewcab Diesel Dually longbed 5spAuto Lariat mbrp S/S dual exhaust Firestone Air Bags stable load bump stops Rancho9000 Eagle Cap 950W/S loaded. Gen awnings 22ft Searay Choc.Lab John MaryAnn
Wanderin fool
Woodland Park, Colo.
Posted: 02/27/09 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
On a proper ride height, the headlights should be a bit high. That indicates you have dropped enough to engage the whole spring pack, including the overloads. If you put that much air in the bags, you are riding on the bags, and not getting the full use of the suspension. I have bags also, but adjust the pressure carefully so i am using the suspension and the bags to support everything. A bit of headlite adjustment may be necessary. I can tell a big difference in the sway when the bags are inflated too much.
Duramax/Lance 835
KTM/Arctic Cats
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Other Forums:
Thedieselplace.com ( chevsforever)
KTMtalk.com (xrcrasher)
Pontoonboating.com (Lounge Lizard)
Arcticchat.com (400crasher)
langenc
Montmorency Co, MI
Posted: 02/27/09 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats-you are aware of a problem and care.
Most dont even know there is a problem and many dont care.
