RV.Net Open Roads Forum: Replaced 2 - 6 volt battieres - hard job
 > Replaced 2 - 6 volt battieres - hard job
Boblou
Good Sam RV Club
Posted: 02/25/09 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I recently purchased 2 6 volt batteries and was all excited about getting the old ones out and the new ones in. I have a 2001 Damon Intruder and they are under the step but too big to lift straight up.
So had to slide them forward and lower them to the ground with a rope.
Next came installing the batteries. This is a 2 man job. I had one of the local mechanics do it and he said it was a heck of a job.
How does everyone else replace their batteries.
bobpie
South NJ USA
Good Sam RV Club
Posted: 02/25/09 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
First I take out the first step to gain access to my batteries, then I make sure all the power is off, disconnect the negitive cable first, then the positive, unbolt the hold down clamps, lift the batteries out, reverse the procedure to install. My batteries are 12 volts. I am thinking of switching to 6 volt batteries myself. $79 apiece at Sams club.
2001 suncrusier, 32-v, Ford V10, 4 Koni FSD, dinning slide, No leaks, 1 wife, 1 westie, life is good! 03 malibu toad sometimes, roadmaster brake pro,roadmaster Blackhawk all terrain tow bar!
Deen
Vancouver, WA
Posted: 02/25/09 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Unlock the battery compartment, slide the roller mounted tray out, disconnect the cables, remove batteries, reverse procedure to install new ones. Just haven't had to do it yet as the Interstate U-2200's are only 7 years old.
tropical36
Southwest Florida_USA
Posted: 02/25/09 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sorry, but am I missing something here? I recently changed out all six batteries in my golf cart which is really reaching down, lifting straight up, over and out. The two under the step of my coach has to be a piece of cake, by comparison. I am at the ripe young age of 69yrs and 5' 4" tall, though. I just don't get it, so you may want to explain further. I mean how much can one six volt battery weigh?
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
Sully2
Cincinnati
Good Sam RV Club
Posted: 02/25/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
About 65 lbs max!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
topflite51
In The Desert of Nevada
Good Sam RV Club
Posted: 02/25/09 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe he's a 90 lb weakling.
David
Just rolling along enjoying life
w/F53 Southwind towing 87 Samurai looking to golf or fish
Simply Despicable
Bob&AnnaMarie
Southern CA - for now
Good Sam RV Club
Posted: 02/25/09 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly how I did it 6 months ago. Just be sure to note ALL the wires that attach to the batteries. I had one that I did not document. I figured it out, but it had me concerned for about an hour.
I also took mine into the battery store (Interstate) when I bought the new ones to avoid the core charge.
Bob
03 Beaver Patriot
04 Suzuki XL-7
Hurricaner
Hurricane Utah
Posted: 02/25/09 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
You need to use one of these. http://www.cartbarn.com/product_info.php........s_id=398&osCsid=0f69117ecf9248d1320622ad
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Count_D_Money
Western MI
Posted: 02/26/09 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Funny, that's how I did it too.
lionel_046
Ohio
Good Sam RV Club
Posted: 02/26/09 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Just changed out the batteries on my 03 Intruder. Due to Damons engineering you can't lift them out. They don't fit through the step opening. You have to slide them out toward the back of the coach & then drop down about 2 feet & reverse the process in. It is a very hard job!! My local dealer charges $50 per battery and after doing the job with the DWs help I understand why. Another big + for the Damon designers
Harry & Gail
USAF Retired
2003 Damon Intruder 350, W-22
2002 Chrysler Sebring Convertible
on a 2006 Master Tow Dolly
