RV.Net Open Roads Forum: Hitch Receivers for Bike Carrier and Blue Ox Tow System
 > Hitch Receivers for Bike Carrier and Blue Ox Tow System
cwenger
Arnold, MD
Posted: 02/26/09 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Swagman hitch mounted bicycle carrier which I would like to mount on my motorhome hitch and still be able to use my Blue Ox tow bar system. I have drop hitch receiver which does work. However, the upper receiver for the bike carrier is 2 inches above the lower receiver for the Blue Ox. I would like to have a dual receiver with the upper receiver at an adjustable height of a foot or more above the lower receiver. Does anyone know if such a product exists? Thanks. Carl.
driveby
Vancouver BC Canada
Posted: 02/26/09 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
yes a dual receiver exists, in fact I believe Blue Ox makes such a beast. I'd head over to your local hitch shop and grab one. just be careful of bike to toad clearance around corners, the bikes will be quite close.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
tallyo
Fort Myers,Florida
Posted: 02/26/09 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
will this work?
http://www.campingworld.com/shopping/item/4-dual-hitch-receiver/34685
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
Wherever I happen to park
Posted: 02/26/09 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if Blue Ox makes such a beast but I do know what they made for me and what I had before
Before: I got a second receiver at the Local RV store and had a local body shop that does welding attach it to the top of the drop hitch, worked very very very well
What blue ox did for me.. Turns out the dealer sold me the wrong drop bar, no problem Blue ox (Factory) sold me another for cost, Since my bike carrier is designed to mount on a ball hitch, they welded a "Tongue" on the top of the drop hitch.. It's bolted on there exactly as it would be in a normal install
s79vette
Twin Lake.Mi.USA
Good Sam RV Club
Posted: 02/28/09 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Camping World sells a bike rack that fits a 2 inch tubing. I bought a 2 foot hitch extender and mounted the rack to it and Blue-Ox into extender. Used only one receiver. No welding and works fine.Just another idea. Steve
2003 Gulfstream Ultra Supreme Ford V10
93 Ext4x4 Dakota,or 2004 Jeep Liberty, Blue Ox, Brake Buddy
Online with Inspiron
http://mysite.verizon.net/res77g99/
A member of http://www.gsowners.com
wny_pat
Western NYS
Posted: 02/28/09 09:00am Link  |  Quote  |  Print  |  Notify Moderator
But doesn't that cut your tow rating in half??
Travelr
Lake Tahoe, Nevada
Good Sam RV Club
Posted: 03/01/09 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I like the dual receiver from Cabela's. www.cabelas.com
It is not staggered such as CW version. It's a straigh-out with the bike mount 4" on top.
Ken Cash
s79vette
Twin Lake.Mi.USA
Good Sam RV Club
Posted: 03/01/09 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
( But doesn't that cut your tow rating in half?? )
I would think if I was towing something with a hi hitch weight in the 100's it might have some effect. All I have for weight is the weight of tow bar.Towed my Liberty 20 some thousand miles with extender installed. With my Liberty I'm under allowable gross tow rating for our motorhome. When we tow Dakota we put bikes in truck.I will say I had to search to get cables long enough to make turns without making problems for myself.
wny_pat
Western NYS
Posted: 03/01/09 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Most extensions have the following type warning statement:
"Load Rating GTW 3500 lbs; Tongue 350 lbs
Load Rating with Weight Distribution Equipment GTW 7000 lbs; Tongue 700 lbs
The limiting factor is the capacity of your hitch. Using a hitch extender will reduce your hitch's overall capacity by 50%"
That statement is for this one. Some cut your hitch's capacity by 30% and others by 50%. Does not matter if it is the weight of what you are pulling or tongue weight, it still cuts the capacity
