RV.Net Open Roads Forum: Truck Campers: EU2000i - Hard to Start
 > EU2000i - Hard to Start
Page of 6
BradW
Flat Rock, Alabama
Posted: 03/11/09 07:46pm Link  |  Print  |  Notify Moderator
Our little Honda generator used to always start on the first or second pull. Now it may take 15 or 20 pulls. Doesn't seem to be flooded and I haven't even pulled the plug to look at it. I suspect semi-clogged carb jets.
I guess it is about 5 or 6 years old and probably has less than 200 hrs of run time.
Anyone have similar problems with their EU2000i?
Thanks,
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
Gary3
Windsor, ON
Posted: 03/11/09 08:05pm Link  |  Print  |  Notify Moderator
The guy next door had a 2000 Honda and never started it all summer when I tried I pulled my guts out before it finally started.I think the longer you let them set the harder they are to start.
Gary  Lance  1191 solar Gen.
jwadd
Fort St James, B.C.
Posted: 03/11/09 08:27pm Link  |  Print  |  Notify Moderator
I believe small engines, even Honda, need to be used regularly. I start my generator and chain saws once a month year around just to make sure they are always ready to go. The lawn mowers, weed whackers, water pumps, and boat motors are started enough in the season of use, that I don't worry about them. Gas stabilizer for them and they always start in the spring.
Clean the carb and change the plugs and you should be good to go.
2006 F350 SRW Superduty Crew
Firestone Air Bags
Tork Lift Stable Loads
2008 27BHS Hornet
dirtengineer
Alaska
Posted: 03/11/09 08:35pm Link  |  Print  |  Notify Moderator
Put some seafoam through it.
Stim
NE Florida
Posted: 03/11/09 08:47pm Link  |  Print  |  Notify Moderator
Most likely cause is water in the fuel. I would dump ALL the gas into a clear container (2 ltr. bottle w/top cut off) and check it for water. Might also be spark plug.
I am a Honda Engine Dealer and I mainly work on 5.5 to 13hp engines on construction equipment. Quite often I find water in the fuel. I always check them for water. I've had Honda Engines sit for up to 6 months and start on the second pull.
ifishsekiu
Kent Wa
Posted: 03/11/09 09:18pm Link  |  Print  |  Notify Moderator
Mine has had a problem from the start(or lack of). If it sits for more then a few weeks I have to take off the cover that sits over the carb and drain the bowl of the carb. Mine has a stainless screw with a 4 inch clear tube that drain the bowl.Turn the screw counter clockwise and the fuel drains.It will be perhaps a couple of teaspoons. After this it will start on the first or second pull. I have tried various fuel stabilizers and never run ethanol blended gas (that I know of). Good luck
old guy
Oregon (pronounced Or e gun)
Posted: 03/11/09 09:45pm Link  |  Print  |  Notify Moderator
I have the same problem with mine, I can put stabil in it and it doesn't help. I'm just about ready to put a 357 into it. I've had it in for service several times and they do a little adjusting and put a new plug in and it starts. go figure.
INSAYN
NW Oregon
Posted: 03/11/09 10:25pm Link  |  Print  |  Notify Moderator
What grade of fuel are you running in it? Regular, Plus, Premium?
I run straight Regular in mine, and drain the carb bowl if I don't plan to use it within a week. I keep the fuel cap turn "OFF" while not in use, and use Sta-bil for anything longer than 2 months. My Honda is going on 5 years old, has the factory plug in still. Always starts easy.
You know, I wonder if breaking it in has anything to do with it. I have a tendency to take break in seriously on my engines and it seems to be paying off. This goes for ATV's, Lawn Mowers, vehicles and even my Honda EU2000.
How?
I always start and run a new engine for a minute or two until it just starts to get warm, shut down and cool completely. Repeat a few more times allowing further levels of heat to acquire each time. Then allow it to completely warm up to operating temp with no load on it for 10-20 minutes. Then allow to cool completely. Change the oil.
After this, I regulate the throttle position (or load for the EU2000)) for a tank or two, and never rev further than 3/4 throttle during this time. (EU2000, stayed on EcoMode). After this break in is done, run it like you stole it!
My results?
1995 Yamaha Warrior 350cc purchased new, still all stock, still running factory spark plug, still starts easy, and has full power.
1997 Polaris 500cc purchased new, still all stock, still running factory spark plug, still starts easy and runs great.
1997 Toyota Tacoma purchased new, now has 147,000 miles, still has factory spark plugs and clutch, runs great, starts easy, passes emissions, and maintains factory rated MPG (avg).
2003 Toro Lawnmower purchased new, mows once a week for ~30 minutes roughly 3-3.5 months a year. Still has factory spark plug, and still starts easy.
2004 Honda EU2000 Genny, ~200 hours, factory spark plug, and easily starts every time.
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
petekerwien
Camano Island, WA
Posted: 03/11/09 10:29pm Link  |  Print  |  Notify Moderator
Don't forget the air cleaner they can get clogged. I run premium. Some loggers I know are having their chainsaws hard starting because of the additives in regular gas, so they are using a higher graqde of fuel
whazoo
Arizona
Posted: 03/11/09 10:41pm Link  |  Print  |  Notify Moderator
I've run small gas engines, mostly Honda, in my paint sprayers for over 30 years. When they start acting up, and they all do, I take them to a lawn mower shop for a going over. One sprayer with a Honda motor is about 15 years old now and going strong, with a little piston slap now but still going strong, and has been to a shop twice in all those years.
Page of 6
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
