RV.Net Open Roads Forum: best wat to anchor down new flat screen tv
 > best wat to anchor down new flat screen tv
happycampersweare
lincoln park michigan
Posted: 03/12/09 10:32pm Link  |  Print  |  Notify Moderator
just installed new 32" flat screen tv but need to anchor tv down any ideas ,don't want to drill holes in the stand if I don't have toforgot to say its on a stand
03 dodge 2500 5.9L diesel
2010 Everest #345s
RJsfishin
Winston Or.
Posted: 03/13/09 04:21am Link  |  Print  |  Notify Moderator
Why, think it mite leak ? Thats what I did,..........screwed the stand down. No leaks either [emoticon]
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KingDome/sat, 2 Oly Cat heaters, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
skipnchar
Topeka or somewhere else
Posted: 03/13/09 08:53am Link  |  Print  |  Notify Moderator
I'd remove the stand and mount it solid to a wall. If you have nothing solid to which it can be attached, then use toggle bolts for the purpose.
Izzy'sMom
North Carolina
Posted: 03/13/09 07:04am Link  |  Print  |  Notify Moderator
I bought a 4' length of Velcro, at Home Depot I believe, and put a 9" - 12" section of the loop side on the wall behind the TV. I then used the full 4' section of the opposing piece (or whatever size you may need - I've got a small 15" TV) to wrap around the TV and anchor to the loop side on the wall. Just remove the 4' piece when you get to camp - you'll have to remember to tie it up before you break camp, however, just like putting down the antenna.
Jason Nipp
Northern Illinois
Posted: 03/13/09 10:32am Link  |  Print  |  Notify Moderator
I am having trouble imagining why you do not want to secure the display through the stand. You say it's a 32" so it's at least 30 pounds. You could also use an arm or flush mount wall bracket.
99 Itasca Spirit 31T
M GO BLUE
Southgate, MI
Posted: 03/13/09 10:37am Link  |  Print  |  Notify Moderator
Gorilla glue...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MrWizard
Traveling
Posted: 03/13/09 10:39am Link  |  Print  |  Notify Moderator
i made wooden 'U' bracket to go around the base and screw too the desk top, holds our 26" HD LCD, very securely ( home made desk, angle iron frame plywood top )
Radiate The Happy
1997 F53 Bounder 36s
Hiking Hunter
Warrior, Alabama, usually
Posted: 03/13/09 10:49am Link  |  Print  |  Notify Moderator
I originally thought I would mount my 26" to a wall or a cabinet side until I realized the weight of the set and the mounting arm, then tried to find something firm enough to secure it to. That, coupled with the fact that the weight of the set would be at the END of the arm bouncing down the road (lots of torque on the mounting bolts). I did a "test mount" and didn't like the way the set on the end of the arm bounced when someone walked through the trailer. I ended up drilling two holes in the stand (the stand would have been surplus anyway), and mounted it to my corner platform for the entertainment center. I painted the bolt heads black so they cannot be seen. I'm very happy with it and it's very secure.
In the places I had to mount the wall mount, it was better for me to drill holes in the flat panel base than the trailer wall.
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
Peg Leg
Anderson, IN
Posted: 03/13/09 11:32am Link  |  Print  |  Notify Moderator
I bolted mine thru the base. It's in a corner so I also ran a support of galvanized angle from the corner up to the upper back of the set. Solid as a sky hook.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
happycampersweare
Posted: 03/13/09 12:49pm Link  |  Print  |  Notify Moderator
thanks everyone I think you talked me into drilling the stand and also making some kind of brace from the back of the tv because with just the stand it has movement when someone walks and this is in a corner to so its not back to the wall but on a angle
