RV.Net Open Roads Forum: Fifth-Wheels: Huge 5th wheel
 > Huge 5th wheel
Fifth-Wheels Related Tips
emmaspride
Southern MI USA
Posted: 03/17/09 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Ford Man wrote:
Are you sure it was not a single wide? I would like to know the company that makes these.
No, it was not a single wide. It was made by Travel Units.
emmaspride
Southern MI USA
traildog wrote:
You mean like these? or these?
Thanks...it was made by your first link...Travel Units
emmaspride
Southern MI USA
Posted: 03/17/09 06:38am Link  |  Quote  |  Print  |  Notify Moderator
davelinde wrote:
what were they using to tow them?
They all had a white semi tractor to pull it. One had been modified by somehow moving the wheels...the other two had tandem axles...The man said that the ministry will have trouble disposing of the altered one for commercial purposes when they are through with it.
emmaspride
Southern MI USA
Posted: 03/17/09 06:39am Link  |  Quote  |  Print  |  Notify Moderator
The Texan wrote:
The only problem is that they(53') are not RVs(399 sq ft max) and can not be registered as an RV. By law they are HUD housing(400 sq ft, or more) and must be titled and registered as a Mobile Home. This can present a multitude of problems from insurance to state permits.
The man said that California is the only state they can't travel in and that a regular driver's license is all that's required.
Rubber Ducky
Central Indiana
Posted: 03/17/09 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I bet I could pull one of those monsters with my 1993 Nissan short bed pickup that has a 4 cylinder engine and automatic transmission. My truck has 39100 actual miles on it. So I'm positive I wouldn't have any trouble pulling that 53 footer!!!
Robert & Tricia
wittmeba
Roanoke, Va
Posted: 03/17/09 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Or these:
http://www.beletti.com/?p=259
You will need at least a stock 2001 PSD for towing..
To my loving wife, Carolyn:
"I dont love you because I need you. I need you because I love you".
Truck Trailer Scale Calculator Applet
RV MFgs
Brake Controllers
RV Links
emmaspride
Southern MI USA
Posted: 03/20/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
wittmeba wrote:
Or these:
They were all white, two with fiber glass siding and one with aluminum...that was the newest.
ol Bombero-JC
Posted: 03/22/09 03:44am Link  |  Quote  |  Print  |  Notify Moderator
Just like the ads on TV - you probably can . . .
. . . . but then there's the stopping part.
emmaspride - Try a search for "HDT" on here - and/or go to the Escapees HDT forum.
The 53 footer is pretty unique. The tow vehicle isn't.
A "singled" class 8 tractor will do everything a dually pickup will -
and obviously LOTS more (including *MUCH* better stopping capability),
- for way less cash (used tractor). And, can be licensed in most states as a MH.
The problem with the 53' in CA (and some other states) isn't the driver's license - it's the overall length. (NO reciprocity for length).
Many MDT & HDT owners pull 5ers in the 36-40 ft range
(in all states).
JC
 > Huge 5th wheel
