RV.Net Open Roads Forum: Travel Trailers: Just brought home our first TT. Whoa...
 > Just brought home our first TT. Whoa...
Travel Trailers Related Tips
mobilefleet
ga
Posted: 03/19/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Too bad it's a Jayco LOL....
Hornet28BHDS
Parker, PA
Good Sam RV Club
Posted: 03/19/09 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
You'll get the hang of everything before you know it! Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
egrove
Dallastown, PA
Posted: 03/19/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I've had both hitches, the EAZ Lift and now the Equalizer. The Equalizer is a better hitch, but I think that is mainly because it does a better job of controlling sway than a friction sway bar. Just my opinion though from trying both, albeit on different trailers. Given that, I never had a problem with the EAZ Lift hitch.
Eric Grove
Dallastown, PA
2009 Jayco Greyhawk 31GS
View an online map showing campgrounds in the US
Add a Visited States Map to your signature
RichieO
Broward County, Florida
Posted: 03/19/09 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Your story reminds me of when I picked up our JayFlight. Towing the TT home in a Tropical storm w/ 35+mph winds...It was the first time I towed anything bigger than our old pop up. Congrat's on your new toy....and may you have many years of healthy camping.
2005 JayFlight 27BH
2003 Dodge Ram 1500 QC 4x2 Hemi 3.92 Super Springs
Our Photo's
TURK2500
Posted: 03/19/09 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
bobbyg123 wrote:
snip....they installed an EAZ hitch with 600lb w/d bars and sway control.....snip.... and while there was some "bobbing" going on,....snip
Just an observation, I believe the Jay Feather EXP 29A has a "dry" TT tongue weight of 570lbs. I'm sure once you departed the dealer that weight increased due to options (awning, LP tanks filled, etc.). Your actual "loaded" (ready for camp) TT tongue weight could be around 700 lbs, depending on your loading habits.
IMO your RV dealership should have supplied you with 800lb rated spring bars, not 600lb.. If you had some "bobbing" going on already, wait until you load-up the TT.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
RLinNH
New Hampshire
Posted: 03/19/09 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats.
At least you got to take delivery on a Rainy day. I have always taken delivery of my TT's on Rainy days. Then I take a flashlight, and I find the leaks. You are already ahead of the curve. Make sure that the dealer fixes the leak, then get out their and take the Family Camping.
2008 Chevrolet 2500 HD Duramax W/Allison Transmission/2007 Ford Expedition Eddie Bauer/2008 Spree by KZ 324 BHS
bobbyg123
Duvall, WA
Posted: 03/19/09 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
IMO your RV dealership should have supplied you with 800lb rated spring bars, not 600lb.. If you had some "bobbing" going on already, wait until you load-up the TT.Turk2500
Yup, that's my thinking too. I mentioned it to them, and they said that the GVWR of the Jayfeather 29A is 6500lbs and 600lb bars are sufficient. I'll check around and find out.
2008 Jayfeather 29A
2007 Ford F-150 5.4L V8
Titan Dude
Snohomish, WA
Good Sam RV Club
Posted: 03/19/09 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Congratulations on the new rig. You will really enjoy it. Soon you will be wondering why it took you so long and be wondering why it's the middle of March and you haven't gone camping yet (like we are wondering). Anyway, maybe we will see you around the campgrounds somewhere. Just look for the dark red Titan and Cougar and come by and say Hi. Enjoy!!
Kelly
2005 Nissan Titan 4x4, Tow Package
2007 Keystone Cougar 243RKS
Our Webshots Page
TURK2500
Posted: 03/19/09 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
bobbyg123 wrote:
snip....and they said that the GVWR of the Jayfeather 29A is 6500lbs and 600lb bars are sufficient....snip
According to the Jayco website the 29A has a UVW of 5,325lbs and a GVWR of 6,850lbs.
Let's assume that your TT loaded weight is 6,000lbs (realistic), and using the 10% to 15% rule for determining ideal loaded tongue weight, puts it at 600lbs (10%) to 900lbs (15%). Well, if you use the dealer's weight of 6,500lbs then the spread is 650lbs (10%) to 975lbs (15%). I don't follow your dealer's logic.
I now wonder if the dealer adjusted your WD hitch correctly .
Putting the tongue weight issue aside, I'm sure you will enjoy the new TT.
Turk2500
bobbyg123
Duvall, WA
Posted: 03/19/09 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
TURK2500 wrote:
I now wonder if the dealer adjusted your WD hitch correctly . Turk2500
You and me both.
