RV.Net Open Roads Forum: Can 1/2 ton truck pull a travel trailer?
 > Can 1/2 ton truck pull a travel trailer?
Page of 5
BUFFALODAN
Buffalo NY
Posted: 03/23/09 09:24am Link  |  Print  |  Notify Moderator
I suggest find a floor plan that suits you first. How many people will be in the TT? You? You and a spouse? Kids/grandkids/friends? Once you find a floor plan see what the specs are then see if the half ton truck you want will pull it. Many, many people tow with half ton rigs. Most of todays half ton pickups can tow between 7000 and 10000 pounds when properly equipped. BUT, with a half ton truck you have to watch payload numbers though, and a heavy tongue weight on a TT will really eat into a half ton's max cargo capacity. So you might end up within the COMBINED weight rating (truck + TT) but over the truck's Gross Weight max (truck + people+ cargo + tongue weight).
2006 KZ Frontier 2505
2006 GMC Yukon XL Denali AWD
2014 Chevy Silverado Double Cab 4WD
1 DW
3DD's
martipr
Haltom City, Texas
Posted: 03/23/09 11:40pm Link  |  Print  |  Notify Moderator
You can buy a 1/2 ton that will pull a 29" 7000 lb trailer all day. I know, I have one( see my sig). On the other hand you can buy a 1/2 ton that would struggle with a 4000 lb 19' trailer. It all depends on the truck.
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
mike77leprechaun
Ishpeming, MI
Posted: 03/24/09 12:04am Link  |  Print  |  Notify Moderator
in all fairness your truck is on a 3/4 ton chassis [emoticon] and I want one [emoticon]
Current Rig: 2015 Springdale 311RE Towed with a 2015 Ram 1500 Outdoorsman Hemi.
"You should really invest in a Diesel 1 ton to properly tow that popup"
ncpotter
North Carolina
Posted: 03/25/09 05:35am Link  |  Print  |  Notify Moderator
Hello Lawrence, I pull a 33ft Rockwood Ultra Lite with my 2005 F150.I know the camper is back there but it pulls it with no problem.If I were to buy another truck though I would definitely upgrade to a F250 or an F350.I live just south of Raleigh and we pull it to Myrtle Beach every summer a couple of times a year.
Kenneth
2005 Ford F-150 Supercrew 4x4
2007 Rockwood 8315ss
Primus brake controller
Equalizer w/d hitch
mhawk4
South Carolina
Posted: 03/25/09 07:35am Link  |  Print  |  Notify Moderator
Lawrence, I am a chevy suburban fan, i tow a 08 jayco 27BH little less than 6000# ready to camp (29" long from tongue to rear bumper)w/ my 1999 5.7 burban. yes i did some modifications - i changed my 3.42gr to a 3.73, w/d is a reese with hp strait line dual cam, i use a hypertech downloader for hp and torque, and my rear shocks are monroe spring loaded. And the most important change is my driving, i stay between 50 and 65mph depending on weather and/or road conditions.
The family is on a budget but never cut back on safety.
if i can get my sig. to work i'll show my set up
good luck!
1997 Ford F350 7.3L DRW
2016 Keystone Hideout 31RBDS
Blue Ox sway pro, Stromberg Carlson A-frame cargo tray CC-255
Luis,Shelia,Noah,Gabriel
All about the family!!">
lawrence617
Archdale, NC
Posted: 05/24/09 08:35am Link  |  Print  |  Notify Moderator
Ok, I did it, bought a 1998 Dodge 1500 Ram 5.2L Longbed 4x4 extended cab and a 2009 Jayco Flight 26BH. Now I want to add horsepower to the Dodge, any suggestions? Cold air intake filter kit? Cat-back exhaust system? Chip?
2009 Jayco Flight 26BH Travel Trailer
1998 Dodge Ram 1500 4x4 Ext Cab Long Bed 5.2L
Reese Equalizer Distribution Hitch
Reese Brake Controller
propane1320
Edmonton, Ab, Canada
Posted: 05/24/09 08:51am Link  |  Print  |  Notify Moderator
Nope, you can't pull a TT with a half ton...[emoticon]
People have been RVing for a long time, and it wasn't always in 500 horse one ton diesels, thats for sure!
Do your homework, play it safe, and drive it with respect, but get out there and enjoy the summer!!!
2003 Winnebago Journey 32T Diesel with propane injection ">
2006 Suzuki XL-7 toad
propane1320
Posted: 05/24/09 08:56am Link  |  Print  |  Notify Moderator
I would have a look at the gears first, if they are 3.73 or better (higher) you could look at a CAI or a chip, but gears are the biggest and most noticeable mod you can make to a TV...
tomkaren13
West Central Florida
Posted: 05/24/09 01:08pm Link  |  Print  |  Notify Moderator
Have 2005 27' Flagstaff Ultra light TT and 2002 GMC Sierra 1500.Ours works nicely. There are alot of options out there.
Psyex
Edmonton Alberta
Posted: 05/24/09 02:50pm Link  |  Print  |  Notify Moderator
My 2001 Dodge Dakota Pulls my 27' 2007 Springdale great and is rated to 6100lbs. I have towed a lot of regular trailers and I would caution you on getting a trailer too close to the top of your tow weight as it may toss your truck around quite a bit a high speed or under windy conditions. Other then that I say go for it.
2007 Keystone Springdale 256RLL
2001 Dodge Dakota V8 5.9L HD Suspension AWD and 4X4
1 Wife, 3 Kids, and Me!!!
Page of 5
