RV.Net Open Roads Forum: Towing: 2003 Forest River Surveyor - Towing Question
Search only in Towing
Open Roads Forum  >  Towing
 > 2003 Forest River Surveyor - Towing Question
Towing Related Tips
reno82
Cardiff by the Sea, CA
Posted: 03/23/09 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Etrailer has quite a few WD hitches in your wieght needs for about $250. The Equalizer is a great hitch, but if money is an issue, a WD hitch and friction bars will do the trick.
kysurveyor
ky
Good Sam RV Club
Posted: 03/23/09 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to try Craigslist for used ones or the site "Hitchtrader.
Keith, Suzy two teenagers and a dog
2005 Seneca 35 GS Super C
2009 Surveyor 294
Pro-Pride 3P hitch
2006 Dodge Durango with 5.7 Liter Hemi
Ductape
On the Road
Posted: 03/23/09 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
600 lb Equalizer will do a great job for you.
Surveyor SV-234
upmm019
Posted: 03/24/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I found a guy in my area on craigslist that says he has one for sale. He is not sure of the brand but it came off of his 26' travel trailer that was at 4880lbs.
Seems like it should work for mine but is there anything I should steer clear of since it's used?
I'm doubtful he has instructions for installation so I'm wondering how difficult it is to install?
I think I know that you need to do on a level surface, and then take height readings of the tow vehicle without the load and then somehow that determines how to set up the hitch but from there I'm fuzzy and perhaps each brand of hitch is different.
I have not see it yet but he is asking $125 ...
Forest River Grand Surveyor MODEL SV-210
Total Dry Weight 3,121 lbs.
Load Capacity 1,790 lbs.
Hitch Weight 386 lbs.
Overall Length (closed) 22' 6"
BarneyS
S.E. Lower Michigan
Good Sam RV Club
Posted: 03/24/09 11:08am Link  |  Quote  |  Print  |  Notify Moderator
It is not hard to set up yourself - it just takes a bit of time. See this sticky thread at the top of this forum for advice. If you run into problems, post again and many members will help you out.
When you get done, you will not only have the satisfaction of knowing it is done correctly, you will have learned a whole lot about your hitch in the process!
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the RV.net Blogs!
Visit our website here
upmm019
Posted: 03/25/09 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I found out the WD for sale locally (private party) is complete but the brackets that go on the camper were sold with the camper.
Where could I find replacement brackets? All I know is the WD is a Quality S, don't know anything more.
Another question, I see these WD with round bar and square bar... does it make a difference? One better than the other?
cronus
Michigan
Posted: 03/25/09 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.etrailer.com/ sells replacement brackets that should work for any generic chain style WD or any local hitch shop will carry them. Round bar hitches hang lower then square (trunnion) style bars and are generally lighter duty. Either will work fine for most trailers.
upmm019
Posted: 03/25/09 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I was checking out their site today....
I'm almost thinking it may be best just to buy a new one from them. Will cost me an extra $80.00 for the brackets and I've found two for sale locally that don't have the TT brackets and one guy wants $125.00 and the other $200.00
I do have one other question about this set up.... I have a drive way that is a little steep and I'm wondering if I'll have the same amount of (Pitch Up and Down) play as I do with the WD hitch?
upmm019
Posted: 06/16/09 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
well, I'm back with trying to get the WD for my camper.
The private party ones all turned out to be old and thought I may be best off if I buy new.
I am looking at the EAZ-Lift Bent Bar WD for sale at camping world but not sure if I should go with the 750lb or 1000lb.
I'm thinking 750lb should be enough but not sure.... Thoughts??
upmm019
Posted: 06/16/09 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Also, what about sway control?
I see some with left or right but how do you know which to choose?
