RV.Net Open Roads Forum: Travel Trailers: adding a second battery
 > adding a second battery
cpaharley2008
york,pa
Posted: 03/23/09 03:55pm Link  |  Print  |  Notify Moderator
I'd like to add another 12 volt battery to my trailer. The battery already there is one year old. Someone told me that with 3 batteries now-two in trailer and one in tv, the alternator will charge the weakest battery and the stronger, newer battery will not get fully charged?
They also mentioned a battery isolator/ What is that and are they only applicable to multiple trailer battery set ups? I'd rather not have to replace both trailer batteries in order to have equal batteries besides my tv battery? Can anyone shed some light here?
2009 Dodge Ram Hemi 4x4 11,300miles- lifetime warranty
2012 Toyota FJ-500 miles
2014 Escape 21' All Season trailer
skipnchar
Topeka or somewhere else
Posted: 03/23/09 04:11pm Link  |  Print  |  Notify Moderator
They told you incorrectly. Your alternator will charge all batteries regardless of their age. It is the BEST situation to have batteries of the same size, same brand and same age but not necessary by any means.
Battery isolaters simply separate your trailer batteries from the battery on the tow vehicle. Unless you're towing with a Ford or Toyota it probably wouldn't be a BAD idea but you can accomplish the same thing with Dodge or GM by simply unplugging the umbilical cord. With a Ford or Toyota the battery is ALWAYS isolated any time the ignition key is in the off position.
It would probably be MORE useful to install a battery isolator switch between the trailer batteries and the trailer itself to prevent items in the trailer like CO detector, LPG detector from discharging your batteries while the trailer is in storage and not plugged in. In EITHER instance they do NOT apply only to multiple battery set ups. Any time you tow a trailer you have a multiple battery situation (one in the tow and one in the trailer) and they charge just fine. Nothing changes when you add a third battery.
Rolling Condo
South Carolina
Posted: 03/23/09 05:49pm Link  |  Print  |  Notify Moderator
For a good understanding of batteries, chargers, inverters, etc. I suggest you look here > 12V side of life part 1
and here> 12V side of life part 2
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
tvman44
Southwest Louisiana
Posted: 03/23/09 06:52pm Link  |  Print  |  Notify Moderator
You'll be fine, go with it. There are more old wives tales on here than truth.
Papa Bob
Husky 16K hitch, Tekonsha P3,
bucky
Bunn NC
Posted: 03/28/09 05:18am Link  |  Print  |  Notify Moderator
My friend with an Expedition can tell you that his TV battery is NOT isolated. My F250 is, maybe it's just the pick ups. I had to jump him in the AM after a furnace night at Wally World.
2005 Cummins 2500 2WD LB quad cab pulling a 2007 Jayco 345bhs. It pulls better than Marcell Ledbetter's mule ever did.
kschitoskey
Albuquerque, NM
Posted: 03/28/09 07:49am Link  |  Print  |  Notify Moderator
I just upgraded to 2 Golf Car 6 volt batteries following the directions on 12 Volt Side of Life site. I found some "factory blems" which had some cosmetic damage at a local industrial battery supply. They ran $35 each - I also put a battery cut off switch on at the same time. Awesome advice on this site.
Good luck.
2012 Keystone Cougar 293 SAB; steady fast stabilizers, golf car batteries
06 Dodge 3/4 T Mega Cab 5.9 ISB - Pacbrake air bags, B&W Companion
campalaska
Alaska
Posted: 03/28/09 01:03pm Link  |  Print  |  Notify Moderator
Good luck.
you got 6 volt deep cycle batteries for $35 each? where can i find that deal?
- 1999 GMC Sierra 2500 Extended Cab 6.5FT Bed
- Firestone Ride-Rite Airbags.
- 1999 Adventurer 810ws
time2roll
Posted: 03/28/09 01:12pm Link  |  Print  |  Notify Moderator
Well they are wrong and gave poor advice. As long as all batteries are in good shape they will all charge together just fine. Up to four in parallel on the trailer is fine.
675w Solar pictures back up
kschitoskey
Albuquerque, NM
Posted: 03/31/09 07:15am Link  |  Print  |  Notify Moderator
We have a local place called Moreco - it's a local industrial battery distributor. I asked one of the aircraft mechanics at work where they source batteries for our King Airs. He sent me to Moreco. They buy batteries in large quantities and get some factory blems regularly. They never know what kind of blems they will get; they day I stopped by they happened to have a couple. Call your local industrial battery supply and ask them.
Kevin
