RV.Net Open Roads Forum: Travel Trailers: Mod to Hold Bumper Cap in Place?
 > Mod to Hold Bumper Cap in Place?
matt7591
So. CA
Posted: 03/25/09 10:16pm Link  |  Print  |  Notify Moderator
A rather modest question but does anyone have any good tricks to hold the bumper cap in place (the cap that covers the stinky slinky storage)?
I've seen a few caps online but I'm thinking someone has to have found a trick with the compression fit ones.
Thanks.
opnspaces
San Diego Ca
Posted: 03/25/09 10:34pm Link  |  Print  |  Notify Moderator
Not my idea, I've just read it on here.
Drill a hole through the cap and drop a nail through it. Or a cotter pin or any other long metal object. The nail will not jump out and the cap cannot come off.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
canoe on top
Denver, CO, US
Posted: 03/25/09 10:42pm Link  |  Print  |  Notify Moderator
If your bumper does not already have a hole or holes in it, drill a hole through the center of the top and bottom of the bumper at the end and drill holes that line up with those holes in the rubber cap. Drop a bolt through all the holes. Actually, with the bolt in place, you probably don't need the rubber cap. Basically, what opnspaces said.
LarryJM
NoVa
Posted: 03/26/09 03:38am Link  |  Print  |  Notify Moderator
I use the nail/bolt concept on mine, but I made a lanyard out of some old bicycle brake cable with some electrical lugs soldered/crimped on each end and fastened one end on the trailer and ran a brass bolt thru the other secured with a nut. That way I won't loose my bolt. As mentioned with this if you use a bolt long enough to go thru both sides of the tube you really don't even need the end cap. Below is a pic of mine and would work on the type of bumper/storage tube you described.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
kknowlton
southeast Idaho, formerly IL/WI border
Posted: 03/26/09 04:29am Link  |  Print  |  Notify Moderator
You can also buy replacement bumper caps (inexpensively) which are more flexible and sort of "pop" into place. They stay put very well - we've used ours for 3 or 4 years now. CW or other RV supplies stores (including those at dealers & CGs) are likely to have them.
jf504mp
Indiana
Posted: 03/26/09 05:16am Link  |  Print  |  Notify Moderator
I put a long bolt thru mine (there was already a hole in the bumper) Then I drilled a small hole thru the retaining bolt and fasten a small chain to it. That way I don't misplace it while dumping....the chain is light weight. I did the same thing with the retaining snap rings for the sway bar tensioners. So far it has saved me from replacing them as I did the first couple of times, before I chained them......
camperbuds3
NE Pennsylvania
Posted: 03/26/09 08:44am Link  |  Print  |  Notify Moderator
That's the kind we switched to after loosing one of my oricginals a couple of years ago. Haven't lost another since switching to them.
2006 Sunline T-2075 TT
2009 F-150 XLT 4x4 SuperCab
willald
NC
Posted: 03/26/09 09:45am Link  |  Print  |  Notify Moderator
Well, first off, I wouldn't recommend storing your sewer hose in that bumper at all. Those of us that have camped for a few years have learned the hard way, that putting the sewer hose in there is not a good idea.
What will eventually happen is this: Every time you put that sewer hose away, it will be somewhat wet from use. All that moisture in there, will eventually rust the inside of your bumper. Taking the hose in and out, eventually the abrasive, rusty surface in there will tear pinholes in your sewer hose, and you'll be replacing your sewer hose every couple of years. And, believe me, NOTHING is worse than realizing *too late*, that you have holes in a sewer hose! Talk about some stink, LOL!
I know some just replace their sewer hose every so often and don't worry about it. Problem with that is, like I said above, it really 'stinks', when you discover a 'holy' sewer hose too late. That, and I've even seen some trailers, where using the bumper too long for sewer hose storage had completely rusted out/rotted the bottom of the bumper. Good friend of mine just bought a used trailer, and now has the fun of having to get/weld on a new rear bumper, 'cause bottom side of old bumper has rusted/rotted to almost nothing, due to previous owner storing sewer hose in there.
There are numerous ways to solve this:
1. Build your own sewer hose storage place, out of PVC pipe, fence post cover, etc. Do some searches on here, you'll find lots of clever solutions people have done along these lines.
2. Coat inside of your bumper with a paint of some kind, that will prevent rusting
3. Install some kind of 'liner' inside bumper, to prevent rusty, abrasive surface from rubbing against hose
(Of course, with #2 or #3, you'd still have to address this issue with bumper end caps)
Anyway, hope this might help you or someone not have to learn these things the hard way, like many of us have. [emoticon]
Will & Angela
2 children that love camping, Stephen & Allison
2012 FR Georgetown 351DS on F53 (V10) Chassis
See it here
hotpepperkid
Kingman AZ
Posted: 03/26/09 08:54am Link  |  Print  |  Notify Moderator
I have never lost one on the road but have lost them while camper was in storage. I thing someone borrowed it and forgot to return it.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
RandACampin
Kathleen, Georgia
Posted: 03/26/09 09:13am Link  |  Print  |  Notify Moderator
Redneck Chrome (duct tape) works. The locking kind that pop into place are your best bet though. Like this
