RV.Net Open Roads Forum: Class C Motorhomes: Air Bags
 > Air Bags
Class C Motorhomes Related Tips
jovyarcher
usa
Posted: 10/05/09 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem as Danny, does one need to remove the leaf to the existing suspension for the air bags? never had a problem with it on my class b but after I transferred to class c this has been a problem to me...
_____________________
truck parts
* This post was edited 10/05/09 05:52pm by jovyarcher *
truck parts
Healeyman
Carrollton, TX
Posted: 10/05/09 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
Hi 'archer,
Specifically WHAT has been a problem for you on your Class C ?
The answer to your question is NO. I did not remove leaves or anything else.
I add enough air (60 psi per side) to raise the rear of the RV 1 1/2 to 2 inches at the wheel well. THAT puts load on the air bags.
The resulting ride in the back of my 22 ft. Class C is quite comfortable now.
Tim
Handbasket
Asheville, NC
Posted: 10/06/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Ditto Healyman. No supplemental air bags that I've ever heard of (I've DIY installed them on three vehicles) require removal of any leaf spring parts. The improved ride quality seems to be simply from 'disengaging' the bottom-most leaf, which on my Chevy is a short, really thick one that is almost inflexible. When you inflate the bags just enough to see a bit of space between the top of that leaf's ends and the bottom of the leaf above, the ride improves. The 'slam-bang' becomes 'bouncy-bounce', so to speak.
Jim, "Be the coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison ('Loafer's Glory'); '07 Forester 2.5 ( the 'HANDBSKT'); '95 Toyota SR5 V-6 4x4 pickup, ARB locker, Bilsteins, Warn hubs & M8000, etc;
'94 968, M030 swaybars ('DOPPLER')
 > Air Bags
