RV.Net Open Roads Forum: Tow Vehicles: Converting SRW to DRW
Search only in Tow Vehicles
 > Converting SRW to DRW
Tow Vehicles Related Tips
LilWick
Arizona
Posted: 04/01/09 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking about converting my SRW 1-ton to a dually. I was thinking it should be as simple as longer wheel studs and a couple of fiberglass fender and wheels and tires of course Am I missing something? I have looked online and all I find are conversion kits to make a 1/2 ton into a dually...I have the same axle as the dually and I have added air bags so weight isn't an issue. I want to get the added stability without having to buy a new truck. Has this been done before?
Thanks,
Alan
2005 Chevy 3500, Duramax with Allison trans. Edge Juice with Attitude programmer, CAI, 4" turbo back exhaust/ cat delete. 285/65-18 BFG At load range E. Boost stick and guages. 2008 Keystone Fuzion 373 (38') toy hauler. triple slide triple axle.
mrsmokey
MA>,02379
Posted: 04/01/09 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
take your time and check it out , studs wont do it the wheels will not fit over the existing drums. You can purchase dual wheel adapter kit and finder kits on line but it is not a true convertion. you might find it cheaper to pick up the rear axle assembly at a bone yard and pick up a new body take off from a truck dealer. you will still have an issue with the front wheels being diffeant.(two spares). you might shop arround fo a late modle wreck and do a full hub replacement . Either way it's expensive to do it right..
SMOKEY
JustLabs
Washington State
Posted: 04/01/09 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Alan
You have the same 11.5" AAM axle as the dually,but they're a different width.
I'd find a dually axle to put uder your truck.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/01/09 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Swap rear axles and springs, add drw front hub adaptors, swap wheels, add two more tires, cut bed sides, add dually fenders with marker lamps, add roof and rear marker lamps, that should about cover it.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
hammer21661
Maryland
Posted: 04/02/09 05:38am Link  |  Quote  |  Print  |  Notify Moderator
my buddy had duallys then he ended up gettin a 3/4 ton short bed. To make a long story short; A gooseneck pulled over scales between 25 and 30,000 # He put monster,like off a road tracter, airbags and built mounts aired up. he said it was as stable as the duallys. But he is insane too. Just thought i'd get it out there.
09 COUGAR 320 SRX
03 Ram 3500 Quad cab SRW Cummins HO Larime 4x4 long bed
04 F 350 psd Sandard cab SRW XLT 4x4 long bed (SOLD)
1997 Yamaha Golfcart
05 Kubota RTV 900 Won't fit,next fith wheel it will, someday.
hammer21661
Maryland
Posted: 04/02/09 05:41am Link  |  Quote  |  Print  |  Notify Moderator
on second thought with that big rig you need like a Ram 5500. or at least a 4500 somethin or other.
~DJ~
Boise, Idaho
Good Sam RV Club
Posted: 04/02/09 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I went through this back in 05 when I wanted my dually. Then I owned an 01 2500 CTD. By the time I priced everything out, dually kit front and rear, 7 tires/wheels, fat fenders, relocating fuel fill door and paint it was over $6000. And after all that I'm sure it would have hurt the retail value.
I ended up with a brand new actual dually for $10,000 difference. Best move I made.
2010 F150 Super Cab XLT 5.4 4X4 Short Box
1988 Nortstar 8' pop up TC
Honda 2000
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
JIMNLIN
Big Cabin, OK
Posted: 04/02/09 07:59am Link  |  Quote  |  Print  |  Notify Moderator
there are ramifications of converting a lower capacity vehicle to a higher capacity vehicle. Read NHTSA regs and in particular about half way down where it pertains to carring load capacity (GVWR/GAWR).
In my state its almost impossible to get any certified alterer or a certified vehicle modifier to change those numbers when the modidication was done by just a individual. I would check with your state for their input on any registration/resale problems or your insurance carrier for any problems from their end.
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
TJ Gordon
Posted: 04/02/09 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Alan
Arrowcraft in Royal Oak Mi. has built high quality dual wheel conversion kits for 3/4 and 1 ton trucks for over 30 years. They are known as a leader in the industry. They can supply you with all the parts you need to do your conversion at a very reasonable price. Check them out at Arrowcraft.com
pupeperson
Silver Springs, NV
Posted: 04/03/09 12:41am Link  |  Quote  |  Print  |  Notify Moderator
Another option is to leave it an SRW and install some Rickson wheels and 19.5" real truck tires to handle the weight.
