RV.Net Open Roads Forum: Tech Issues: Portable Generator Auxiliary Fuel Tank
 > Portable Generator Auxiliary Fuel Tank
jim_1932
home
Posted: 04/02/09 12:49pm Link  |  Print  |  Notify Moderator
Tony Cornett used a marine tank for his Honda generator. Will the same wok for a Yamaha Generator? O, has anyone done this for a Yamaha generator?
pulsar
Lewisville, NC
Posted: 04/02/09 12:57pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2015 Meridian 36M
2006 CR-V toad
3 golden retrievers (Breeze, Jinks, Razz)
1 border collie (Boogie)
Bumpyroad
Virginia
Posted: 04/02/09 01:34pm Link  |  Print  |  Notify Moderator
my marine tanks (I assume you mean like for an outboard motor) all work with a fuel pump pulling gasoline up and out of the tanks. I thought that most portable gas engines are fueled by gravity?
bumpy
FXSTOHIO
Ohio
Posted: 04/02/09 02:00pm Link  |  Print  |  Notify Moderator
Here is a website that might help you with your question. How to add an aux fuel tank to a generator
2008 Pilgrim Lite 21LRB
2014 Chevy Silverado Z71 Double Cab 4x4 5.3 V8 3.42 Rear End
Yamaha EF2400IS
Amateur Call N8HXR
Bumpyroad
Virginia
Posted: 04/02/09 03:19pm Link  |  Print  |  Notify Moderator
does that really work, gas gets sucked into the tank? is there a fuel pump on a gen.set. motor? or is it gravity fed?
bumpy
FXSTOHIO
Ohio
Posted: 04/02/09 03:35pm Link  |  Print  |  Notify Moderator
bumpy
Never tried it but think it would work off vacuum once the fuel starts moving it would continue as long as engine was running. That’s my thinking.
FXSTOHIO
Ohio
Posted: 04/02/09 03:53pm Link  |  Print  |  Notify Moderator
After some reading looks like it will only work with a Honda generator because they do have a fuel pump. The only Yamaha with a fuel pump is the 1000 from what I am reading.
rjf7g
Virginia
Posted: 04/02/09 08:45pm Link  |  Print  |  Notify Moderator
I have a Honda EU2000i and a 6 gallon marine tank rigged up to it. There's a primer bulb in between the two of them. I am thinking a fuel pump would be necessary even in this set up.
1999 American Cruiser Class B
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
Adam-12
6 LAND
Posted: 04/03/09 02:47am Link  |  Print  |  Notify Moderator
The EU2000i has no problem of sucking fuel out from an aux tank. I"m not sure if that genny has a built in fuel pump or not. Either way, it must have either vacuum (suction) or a fuel pump. It does work nicely even if the fuel tank sits below the generator.
* This post was edited 04/03/09 05:20am by Adam-12 *
Silverado 2500HD Duramax DIESEL/4x4/CC/Z71">
31' Travel Trailer
2 Honda EU2000i's (parallel)
ICOM 7000
Random wire, dipoles, verticals
Hunting/Fishing gear
Welding/Fabricator
Life endowment member NRA
