weymard
NORMANDY
Great job ! Very interesting and useful ! Thanks !
Lance 815 2007
France, Normandy
Fish 'n ' Grits
Hollywood, SC , USA
The only thing I would add is; Keep Sta - Bil in your gas, and run your generator now and then. I know it's easy to forget about it until it's needed (and won't crank!) I try to run mine at least twice a month. I start it and plug in a fan or some other constant load and let it run 15 minutes or so. That seems to keep it happy and ready to start next time.
Billy & Dale
'99 F350 DRW Superduty
'02 Lance 1161
Salli the "Schnoodle"
AISURFFISH
BERLIN MARYLAND
SidKaye wrote: Ron, thanks for a great post. I have a EU1000i, do you know if the procedure would be the same or similar. Mine has been running rough on ECO and jut today I was searching the net for carb maintenance.
Sidney
i have no idea what the 1000 carb looks like so i cant comment but the principles are the same.
2004 F350 V-10 GAS CREW CAB SHORT BED BLACK
THE LANCE MAX 881 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF BEER
A.M.S.A. MEMBERS HIM 1025/HER 1026/JUNIOR 93
MID ATLANTIC TRUCK CAMPER RALLY INFORMATION PAGE
capterik
Fort Lauderdale, Florida
Only thing I would add is to do this when you put it away instead of waiting, as shapeshifter found out, when he needed it it didn't work. Great writeup.
2003 Kodiak 5500
2006 Bigfoot 25C9.4SB
KVH inmotion Satellite
Stable Lift
JacintoKid
San Antonio, Texas (formerly sheepdog)
Thanks. Mine is way overdue and I was planning on getting this done before we go up to the mountains this summer. You have just made it very easy. Thanks AISURFFISH
07.5' Dodge 3500 DRW 4x4 L/B Cummins
08 Arctic Fox 990
(2) KLX 400's and a flotilla of small boats
ShapeShifter
Buffalo, NY
capterik wrote: Only thing I would add is to do this when you put it away instead of waiting, as shapeshifter found out, when he needed it it didn't work.
It didn't let me down -- it worked, it just took several extra pulls. It normally starts on the first or second pull, this time it took a dozen or so. It's not used all the time, but it is used several times a year, and I store it filled with Sta-Bil treated gas.
But it's close to 10 years old now, and even though it's been treated well, it probably could use a good cleaning to bring it back to 100%.
I've been reluctant to touch the carb, but with these great instructions I have no more worries. OK, maybe one worry -- when putting the main jet back, is there any adjustment that needs to be made? Or does it just go back in and the retaining screw gets snugged down?
wnjj
Cornelius, Oregon
ShapeShifter wrote: I've been reluctant to touch the carb, but with these great instructions I have no more worries. OK, maybe one worry -- when putting the main jet back, is there any adjustment that needs to be made? Or does it just go back in and the retaining screw gets snugged down?
Just snug it up. The jet diameter is what sets the "adjustment".
wnjj
Cornelius, Oregon
capterik wrote: Only thing I would add is to do this when you put it away instead of waiting, as shapeshifter found out, when he needed it it didn't work. Great writeup.
Unless you drain the gas or use fuel stabilizer, it won't do any good to clean it before you put it away. Mine had problems because I put it away and the gas went bad. It was running perfectly when I had used it previously. In my case the carb cleaning was needed to get it running again.
curt12914
Northern NY State
Great post!!!
However, I don't agree with some of the posts after the original. It's probably a good idea to clean the float bowl periodicaly, but there is no reason to remove the jet unless it's dirty or plugged.
I, also don't put much credence in the "bad gas" theory. I have left untreated gas in my "twins" for several winters. It may have taken a little squirt of gas in the spark plug or through the carb to first get it started, but once they start, I have never had a problem.
Since they have no filter, it's imperative to be careful handling the fuel. I would never use a steel can (that could rust) or never completely empty the can when refilling.
I'm not much for "snake oil", but if they run a little rough, Sea Foam is by far the best stuff I have found. It sure beats tearing the carb apart if you don't have to!
05 Ford F-350 Lariat CC 4X4 PSD DRW Line X Retrax
02 Montana Big Sky 3295 RK (2) Honda EU2000is
When my grown kids were inspecting our new fifth wheel, one asked why we bought a trailer that sleeps 4. My reply was that we couldn't find one that sleeps 2!
AISURFFISH
BERLIN MARYLAND
Mine prolly did not need to be removed again. it would not start and after i drained the gas i knew why... The gas was almost brown in color and smelled really bad. It was bad gas ... So after the new gas new plug and clean carb it ran as good as new...
