RV.Net Open Roads Forum: Tech Issues: EZ lube bearings
 > EZ lube bearings
Tech Issues Related Tips
jim behr
Hibbing, Minnesota
Good Sam RV Club
Posted: 04/05/09 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I have too start thinking about getting ready for this season. When you grease the EZ lube bearings in the fifth wheel, how do you know if you have enough grease or when you have overgreased? last year I just pumped about 4 pumps into each wheel.Have put on about 6000 miles since with no problems.
2 polar bears
2005 Ford 250 powerstroke
2007 Jayco Eagle 29.9 rls
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 04/05/09 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Here is the full manual take a look at page 54 EZ Lube
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
PopBeavers
San Jose, CA
Posted: 04/05/09 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I pump slowly and gently by hand until I see clean grease flowing out all the way around.
Every three years I disassemble to inspect the bearing and race. In that case I hand pack.
There is a theory around here that using a pressure grease gun sometimes causes the seals to fail.
Wayne in San Jose
TV1:2002 Chevy 1500HD 4wd Crew Cab,Valley Odyssey brake ctlr,McKesh mirrors
TV2:2008 GMC 2500HD long bed 4wd Crew Cab,GMC brake ctlr,GMC mirrors
TT:Trailmanor 2720
Honda 2000
Yamaha WR250R,Polaris Sportsman 700 X2,Polaris Scrambler 500
RJsfishin
Winston Or.
Posted: 04/05/09 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Not if you limit it to 1-2 pumps per year.
Do what feels good, but normally w/ ezlube, or BBs, there is no need to ever disassemble the hub. (no matter what the book says to cover their butts)
Give the wheel 1-2 pumps of grease.
Then jack up each wheel, spin it. If it is noisy, then yes, you better pull the hub,...see whats goin on.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
Chuck&Gail
In the Colorado Mountains
Posted: 04/05/09 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I did as said above on last TT. Worked great for 7 years. Still doing great when sold, never any grease on brakes. Just pump slow and DO NOT use an air grease gun.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
C Schomer
Buckeye, Az.
Posted: 04/05/09 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
My first 5er w/ezlube got grease on the brakes before it was out of the 1 yr warranty so I never trusted them. My dealer said the same thing and Dexter warranteed a complete brake job so I hand pack. Craig
Gdetrailer
PA
Posted: 04/05/09 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend you read MY comments in THIS POST!
Pumping grease in, it HAS to go somewhere... Just where do you think some of it will end up? INSIDE on your brakes!
I am not an expert on the EZ Lube axles but have been around the block when it comes to maintaining my own vehicles and trailers. I would never consider blindly pumping grease into a hub, you are begging for trouble down the road.
LarryJM
NoVa
Posted: 04/05/09 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Check out my post just prior to this on the Dexter EZ-lube system maintenance by searching my posts.
There are a lot of misconceptions on how this system is supposed to work by a lot of folks that have never had it so be careful who you believe and who you discard as being uninformed.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Gdetrailer
PA
Posted: 04/06/09 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Please read my rebuttal to a supposed "informed" EZ-Lube user HERE which includes direct links to DEXTER'S OWN DOCUMENTATION which is not here say from a user.
 > EZ lube bearings
