SoCalDesertRider
SanDiego, CA, USA
My truck has so much more power and gets better mileage too with Hydrogen in the tires.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
BrandonR
Oregon
My tires contain a mixture of gasses, including but not limited to Carbon Dioxide, Dihydrous Monoxide, Diatomic Nitrogen, Diatomic Oxygen, various Noble Gasses and some not so noble ones.
Brandon Reed
Albany, OR
SoCalDesertRider
SanDiego, CA, USA
Hey maybe you can market some of that ingenious mix of gasses and sell it for a nice profit! I'm sure there must be all sorts of great uses for it.
Oh did you hear they're banning dihydrous monoxide? Supposedly it causes too many accidents on the freeway. Safety hazard ya know...
Matthew_B
The boonies near Dallas, Oregon
BrandonR wrote: My tires contain a mixture of gasses, including but not limited to Carbon Dioxide, Dihydrous Monoxide, Diatomic Nitrogen, Diatomic Oxygen, various Noble Gasses and some not so noble ones.
The noble gasses go away real fast. They are smaller plus they don't interact so they go right through rubber quite a bit faster.
I've seen balloons filled with Argon, Neon and Xenon and was amazed how much faster the balloons deflated compared to an air filled one.
fueling around
NW MN
99.99% dry nitrogen gas.
Aircraft tires use it for the lack of oxygen. I've seen the results of aircraft tires filled with air and the results are pretty spectacular.
The RV use is for DRY. My original rims were very rusty on the inside from wet (oxygenated) air.
I try to use air that comes from a tank reservoir. It helps drop the moisture out. Those quick fill units common at many convenience stores or your portable unit pump the moisture laden air directly into your tire.
My bits.
John
1997 Dodge 2500 CTD
1989 Cascade 8½ Self-contained Truck Camper
?? Eureka Timberline 4 tent
iwon415
Northern California
If you are nervous about driving a truck with a camper on it, then by all means use nitrogen in your tires, its recommended by all nervous camper owners.
TimH
~DJ~
Boise, Idaho
Good Sam RV Club
I like the cool moist air in my tires. They run cooler!!!
In fact, I filled my compressor last January with 5 degree air. When I put my camper on shortly I will fill the tires with that cold air to keep them cool all summer.
Then this August I will fill the compressor again with 100+ degree air to fill up the winter tires. Really helps melt the ice for traction.
2010 F150 Super Cab XLT 5.4 4X4 Short Box
2010 18' Springdale Rugged Terrain
1988 Nortstar 8' pop up TC
Honda 2000
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
INSAYN
NW Oregon
Here's an experiment for you John, put pure dry N2 in your inner tires, and gas station air in your outer tires. Get back to us on what you find out.
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
TC John
Chihcago
They tire dealer called and said they are running a special on Helium...so I Opted for that gas instead...
BradW
Flat Rock, Alabama
I used to have a free and inexhaustable supply of R12 and R22 back in the 70's. I can't tell you how many car, truck, trailer and dirt bike tires I owned which never saw a molecule of air.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
