RV.Net Open Roads Forum: Tow Vehicles: f150 ford
Search only in Tow Vehicles
 > f150 ford
Tow Vehicles Related Tips
windellmc
Indianapolis
Posted: 04/11/09 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Even if your trailer is 5k lbs that truck should pull it fine. In fact I would expect overdrive to be useable if you have the 17" wheels. There is not a huge difference (5% which is probably 100 rpm on the highway) between 3.55 and 3.73 and a 3.73 gear is rated to pull over 9k lbs in an F150.
brighteyes818
New Britain, CT
Good Sam RV Club
Posted: 04/11/09 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Now I'm confused, stated is the 3.73 is not much different than the 3.55 but it seems the towing capacity goes up quite a bit with the 3.73's, If correct that would be 3.55 towing 6500 or 3.73 towing 9000lbs.
rfryer
Phoenix
Good Sam RV Club
Posted: 04/11/09 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
brighteyes818 wrote:
Hi,
The 6400# the poster mentioned sounds low, maybe for a 4.6 engine? I suspect the rating is higher for a 5.4. That actually makes the problem look worse if she's struggling with a 4000# TT. I'm waiting for someone with better reference material than myself to answer.
mosseater
Dillsburg, PA
Posted: 04/11/09 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
No question that engine loves to spin, but that doesn`t sound right to me either. Brakes dragging? Exhaust blocked? Intake blocked? Computer trouble? Have the dealer look at it.
Sunset Creek 298 BH
Beaker
Brevard, NC
Good Sam RV Club
Posted: 04/11/09 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Should pull on flat in OD with no problem.
If you have had no problems with this truck not
towing, maybe look at trailer brakes, bearings, brake controller, etc.
2008 Silverado 2500HD Duramax
1998 23' Jayco lite
Donny D
Niagara Region
Posted: 04/11/09 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
The #6400 tow rating is for the 4.6L. Thats what I have and it pulls 5000 no problem. Probably a tv problem.
2007 F-150 FX2 crew cab
2009 KZ Spree 240BHS
Me
DW
DD's '93 & '95
DS '94
My best friend Jake our red fox Lab '07
"Old enough to know better, Still to young to care"
bounder98
S. Texas
Good Sam RV Club
Posted: 04/11/09 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone!! I'm talking to the dealer on Monday,it will take a couple of days to get it in,I'm sure, but I will let you know what happens after they look at it. Once again thank you, you all told me what I needed to hear. Lou
labman1014
hattiesburg, ms
Good Sam RV Club
Posted: 04/11/09 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
ok, while i was driving my 08 F150 today on the highway, i was thinking about this and not to be a smart butt about it, but when you say you turned off the OD, did you hit the button or did you drop out of "D" to "2"? and again, im not calling anyone stupid here, just at 50mph and 3300rpm, sounds like your were not in 3rd gear.
i tow my 7200# with OD off at 60mph at 2250rpm.
i just know on older trucks, they had a "D" with a circle around it for OD and then a just plain "D" for out of OD. just a thought!!!
TV-2008 Ford F150 SCrew, 4X4, 5.4L, 3.73LS, Rear Camera
TT-2008 Surveyor SV-304LE
Hensley Arrow-P3
Just me-'77, the wife-'81, daughter-'05, son-'07, and son-Dec '09!!!
Redoildoctor
Land of the Fruits...Nuts...and The Govenator!!!
Posted: 04/12/09 12:17am Link  |  Quote  |  Print  |  Notify Moderator
Agree with everyone here that something doesnt sound right.
Unless on your route you were going uphills both ways. My dad went that way when he was a kid. Only he was barefoot and it was in the snow.
CHRMAN
left coast
Posted: 04/12/09 01:27am Link  |  Quote  |  Print  |  Notify Moderator
4.10/4.30 gear & a Hypertech tuner set for premuim fuel will turn that truck into a TOW BEAST. But it does sound like the power is lower than normal production power. Get it on a rear wheel Dynometer for proof. IMO a 3.55 ratio is a Joke for towing!!!
 > f150 ford
