RV.Net Open Roads Forum: Travel Trailers: Going from 205/75R15 to 225/75R15?
 > Going from 205/75R15 to 225/75R15?
Travel Trailers Related Tips
DiscoStu
Calgary
Posted: 04/14/09 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 25' Komfort trailer which is about 6500 lbs loaded. I need to replace the 10 year old Goodyears, which are 205/75R15 Load Range C. I have heard good things about the Maxxis tires and am thinking of going slightly bigger, 225/75R15, so I can move up to Load Range D. Does anyone see a problem with this? It is only a 1.2" change in diameter so as long as it still clears the fenders I should be good right?
tvman44
Southwest Louisiana
Posted: 04/14/09 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea as long as they clear each other and the sprins/frame and fender.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
cathcartww
Stone Harbor, NJ
Good Sam RV Club
Posted: 04/14/09 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think it is a great idea to go up in size and load rating if you have the room. In addition to the fenders, you also have to check the space between the front and rear tire, and the clearance between the inside of the tire and the trailer frame itself as the 225 is slightly wider as well as bigger in diameter. I think the bigger ones will probably fit, but you better check. My last set of tires were Maxxis, and I did not have any problems even though they were running close to maximum load.
Bill and Kate from Stone Harbor, NJ
with Sunny (the parti poodle) and Molson (the goldendoodle)
1995 Chevy/Quigley 4x4 G20 Van (the "Salty Dog")
2005 Jay Feather 29N (the "Salty Dog House")
Pro Series SC hitch
Midnightpumpkin
Concord Twp, Lake County, Ohio
Good Sam RV Club
Posted: 04/14/09 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Check the width of your rims. Our Rockwood has rims that are only 5" wide. The 5" wide rim is not recommended for a ST225/75R15 tire.
I replaced my St205/75R15 LR C tires with Denman ST205/75R15 LR D.
The Denmans seem to have as good a reputation as the Maxxis, so far I am happpy with them.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
skipnchar
Topeka Kansas USA
Posted: 04/14/09 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hummm...you got 10 years out of the 6 ply tires and you think you need 8 ply?
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
lotust
Long Island NY
Posted: 04/14/09 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
wow 10 years is allot of time. You must have taken really good care of them not to dry rot.
  • 2006 Jayco Jay Flight 27 BH.(paid cash :-)
    2008 toyota tundra 5.7L w/tow Off road Pkg 4:30 gears (not paid off:-(
    Yamaha Ef2400is
    The wife and our boxer(RIP Buster), Loving Camping!
RichieO
Broward County, Florida
Posted: 04/14/09 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the 205 75R/15 Maxxis tires on our TT about a week ago and went with the larger 225 75R15 tire. Like previously posted just make sure you have enough clearance in the wheel well which you should. I DID NOT go with Maxxis...had 2 blowouts within a month on the 5 year old Maxxis tires that looked just fine prior to the blowouts. The Load Range D tires are a good idea. I noticed an instant change in handling when I changed to the larger tire.
2005 JayFlight 27BH
2003 Dodge Ram 1500 QC 4x2 Hemi 3.92 Super Springs
Our Photo's
DiscoStu
Calgary
Posted: 04/15/09 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies everyone, I checked last night and the bigger tires will fit, there is a ton of room, not sure about the rim width though. I bought this trailer off a friend and this will be my 4th year in it. The tires have served me well and no I haven't really taken care of them, they've never been covered, they aren't inflated to max pressure. I could probably get another year out of them but I think I am pushing my luck and figured I might as well upgrade to a D rated tire since I'm replacing them anyway.
