RV.Net Open Roads Forum: Tech Issues: Air conditioner/roof leak
 > Air conditioner/roof leak
Tech Issues Related Tips
Wrace
Seattle WA
Posted: 04/16/09 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
1997 Nash TT with typical Colman air conditioner.I put eternabond tape on all roof seams, skylights, vents etc last summer (but not the air conditioner of course).
This winter a leak developed that is dripping from the air conditioner. Probably from the prolonged and heavy snow we had last winter.
Is there some sort of foam or tape gasket between the air conditioner unit and the surface of the rubber roof that could be leaking? Do these typically need to be replaced after so many years?
Are there any sort of drain holes or vent holes on the air conditioner that may be plugged and routing water where it should not be?
Thanks
hypoxia
Arizona
Posted: 04/16/09 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
Take the A/C cover off of the interior. There are normally 4 bolts that will be exposed. Tighten them, it is common for the seal to leak and all it needs it to be tightened down. It is just a foam gasket between the A/C unit ant the roof.
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 04/16/09 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
There is a gasket under the air conditioner on the roof and the roof. You will need to lift the unit to install a new one.
The Falcon
Monterey Co, CA, USA
Good Sam RV Club
Posted: 04/16/09 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.bryantrv.com/roofacleaks.html
Check this site. It is www.bryantrv.com. Go to Troubleshooting then Water Leaks.
Precision Guesses
Joe&Jan and--Penny, our city dogpound escapee
2003 Hurricane 30Q V10
2004 Jeep Liberty, Blue Ox, Brake Buddy
BIKERK9
Santa Cruz, CA
Good Sam RV Club
Posted: 04/17/09 01:03am Link  |  Quote  |  Print  |  Notify Moderator
I recommend replacing the foam gasket. Note: The gaskets come in different thicknesses.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
Roadfrog
Chilliwack, BC Canada
Posted: 04/17/09 07:47am Link  |  Quote  |  Print  |  Notify Moderator
If the water is leaking from within the unit itself, (as opposed to around the outside), check to make sure that water coming through the outside shroud/ac cover, is not coming into the ac unit and through the ducts due to clogged or blocked drain holes. That's what was causing my leak. It wasn't the gasket.
Cheers
Chris
1999 Winnebago Itasca Spirit 29N
1988 Campion Allante 195
Wrace
Seattle WA
Posted: 04/17/09 09:42am Link  |  Quote  |  Print  |  Notify Moderator
That may be the case as the water appears to be coming from within the unit itself, but of course it is hard to tell for sure with the way water can travel.
Wrace
Seattle WA
Posted: 04/17/09 09:55am Link  |  Quote  |  Print  |  Notify Moderator
If it looks like it's in fact the gasket, can this be ordered online from somewhere? Camping world maybe? Both the rv shops I used to use around here are out of business as far as I know.
I'm concerned about my weight 270lbs damaging the roof, is there any technique used to spread the load on the roof a bit that may help with this?
Thanks
bingoldsby
Oregon State Parks - somewhere
Posted: 04/17/09 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Check the bolts first. Don't over-tighten them, but I'll bet you need to take a turn on all of them. If that fixes the problem, you can either worry about it some more and replace the gasket, or be satisfied that it's ok for another few years.
A standard recommendation and maintenance proceedure is to tighten those bolts occasionally. I've done that to my 22 year old (almost 3 years to me) airconditioners, and it fixed a leak in the rear one. I'm going to replace gaskets some time, I suppose, but I'm not going to loose sleep over it - mostly because there is no more dripping on me when I'm in bed.
Brian K7ZRZ
Campground Hosting - Oregon State Parks
1987 30' Holiday Rambler Class A
GL1800 Goldwing - Honda Scooter Mounted
2000 Silver Miata LS Toad
Serious WiFi
Jim83Itasca
La Quinta Calif
Posted: 04/17/09 10:45am Link  |  Quote  |  Print  |  Notify Moderator
During some very heavy rain here in the low desert this spring I developed a leak in the front AC so it was time for a fix....
The A.C. is fairly new on the installation so off was the word.....Over the years the roof has decided to sag on my 83 Itasca but not toooo much.
The heavy weight of the unit bouncing down the road over the years will cause the sag and I measured with a straight edge (long) a dab over 5/16 inch of roof depression.
Two gaskets solved the problem since another heavy rain dropped in about two weeks later......NO problems now...
Jim
