RV.Net Open Roads Forum: Class A Motorhomes: Carbon Monoxide Detector Check
 > Carbon Monoxide Detector Check
Pbronson
Syracuse, NY
Good Sam RV Club
Posted: 04/30/09 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
HVAC Supply houses usually sell CO in a spray can to test detectors. They come in a kit that includes a plactic shower cap that is put over the detector, the tube from the can is poked thru the cap and a two second burst of CO is administered. Tape is put over the hole in the cap and within a few minutes the detector should go off. It is not like a smoke detector as it may take a few minutes to beep.
As said before, they should be replaced every 6 years as they do wear out without warning.
Pete
Pete and Pat
2004 Itasca Horizon
havin fun
don't know yet we are not their yet .
Good Sam RV Club
Posted: 04/30/09 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
call your local fire dept. they can check it for you .that's what we did .going to replace ours soon .they said that they are only good for 5 years or so . same with the smoke detector and propane detector .
retired
havin fun with 1999 georgie boy 3515
and the wife too .
V-10 ford
It's hard to make a come back if you haven't been any where ? !!
North Hampton Local Weather
