The overhang ( I don't know the technical term for it). on my 5er is sagging a little. It is the area in the front that you back under to hitch up. The material that is under there is sagging a little. Not big problem now, but I don't want it to become one. Any idea on how to fix it.
Ours did the same thing and I used a stud finder to find the metal cross bracing for the frame and used stainless self tapping screws with washers to pull it back up tight.
Hunter11 wrote: Ours did the same thing and I used a stud finder to find the metal cross bracing for the frame and used stainless self tapping screws with washers to pull it back up tight.
We had a 5w do the same thing and I fixed it just like Hunter11. The screws did back out again later so make sure you use LockTite.
