RV.Net Open Roads Forum: Travel Trailers: Sealing underbelly
 > Sealing underbelly
Travel Trailers Related Tips
Dandy
NorthEast
Posted: 04/28/09 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Need some good suggestions to sealing the sealed underbelly. I need to get around the small openings that are there to prevent anymore rodent infestation. The expanding foam is too messy and will not get into the small areas, plus it is not pleaseing to look at. Any other ideas would be appreciated.
Chevy 1/2 Ton Crew Z71 / 3.73 / 5.3L
Rockwood 8317 SS (Yes, it's a 1/2 ton pulling it)
Reese WD System with HP Dual Cam
Primus Brake Controller
Factory Receiver Hitch
McKesh Mirrors
swebber
Brunswick , MD
Posted: 04/28/09 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Steel wool will fill voids. Silicone will also work. Personally I like using expanding foam. You can always cut off the excess after it hardens up.
Steve & Tracy Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 4000 gennie
Our Camping Pic's
mecreature
Indianapolis, IN
Posted: 04/28/09 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I went around mine with some gorilla tape. I put steel wool and a couple dryer sheets in the voids and cut a slit in the tape to fit snug. I worked out with about 3 pieces overlapping them..it covered about a 8x8 inch area.. I went around everything.
it sticks great to a properly prepared area. If it comes off I will do it again.. and it matches great..
I dont have an underbelly but that black tarp stuff.
BTW - I live in farm country and mice you have to deal with. I keep traps set through the winter and in previous years have caught several.. this year I had zero.. no droppings or any sign of mice.
98 Skyline Nomad 1950 Compact
2004 Silverado 1500 EXT. 5.3 3.42 Axle 2wd
mike77leprechaun
Ishpeming, MI
Posted: 04/28/09 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
My Jayco was filled with expanding foam from the factory
2008 Jayco Jayflight 30BHS 40th Anniversary Edition
Jayco Jafari member 29183
Eternabond Believer!
Nights Camped in 2009- 16
TXiceman
(Near) Houston,TX
Posted: 04/28/09 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than steel wool which will rust, use bronze wool (available from Marine supply stores). The little rodents will eat through the foam.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
radardog
delaware
Posted: 04/28/09 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
BINGO!!!!! TX has the best answer, a little Gorilla glue applied to the edges of the opening will help the bronze wool stay in place.
The fan always wins
goingnorth
Petersburg, MI
Posted: 04/30/09 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I just did mine with silicone seams to work ok, just did 400 mile trip and it held up. From the factory mine had exp. foam but I tore most of that off adding wireing, insulating water lines and installing tornado.
08 F350 FX4 CC SB 6.4L
09 Keystone Passport 290BH UF elec jack,30"scissor jacks+Eliminator Strut Stabilizer,PD9160+wizard,custom bumper hitch,added 18.5gal FW tank,Reese dualcam 800# WD,Fantastic Fan,Axle Flip,Lexan screen door covers.
My Mods.
