RV.Net Open Roads Forum: fresh water hook up & city water connection
 > fresh water hook up & city water connection
Danford50
North Carolina
Posted: 04/29/09 08:52pm Link  |  Print  |  Notify Moderator
what is the different between the two?
doug frazier
Remlap,Al
Posted: 04/29/09 08:56pm Link  |  Print  |  Notify Moderator
ive had some city water i wouldnt call fresh. but they are the same.
2006 Dodge 1500 Quad, 5.7 HEMI, 3.92gears, antispin diff
2005 2501 Rockwood (4136lb dry)
1000lb Equal-i-zer Hitch
Honda EU3000is
Prodigy
Donny D
Niagara Region
The city water connection is usually the direct hose connection for sites with a water hookup, fresh water is usually a gravity fed straight to your FW holding tank. Hope this helps.
2010 F-150 FX2 crew cab
2009 KZ Spree 240BHS
Me
DW
DD's '93 & '95
DS '94
My best friend Jake our red fox Lab '07
"Old enough to know better, Still to young to care"
brirene
midwest
Posted: 04/29/09 10:00pm Link  |  Print  |  Notify Moderator
city water feeds the line directly; fresh water feeds the tank and the water is then circulated into the lines when you use your on board pump.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Adam-12
6 LAND
Posted: 04/30/09 02:13am Link  |  Print  |  Notify Moderator
Make darn well sure the you have a water pressure regulator on your hose between the city water faucet and your city water inlet connection!!! Otherwise, many campgrounds that have water connections have pressure that can be around 100psi. Anything over 50psi for an RV is pushing it and may cause your plastic flex pipe(s) to burst.
You can find cheap yet fully functional water pressure valves at any RV parts store or camping world!
Silverado 2500HD Duramax DIESEL/4x4/CC/Z71">
31' Travel Trailer
2 Honda EU2000i's (parallel)
ICOM 7000
Random wire, dipoles, verticals
Hunting/Fishing gear
Welding/Fabricator
Life endowment member NRA
skipnchar
Topeka or somewhere else
Posted: 04/30/09 06:48am Link  |  Print  |  Notify Moderator
Honestly I've never heard the two separated before. There is usually only ONE water hook up and it had BETTER be fresh (Potable). It IS often furnished by a "city" or municipality of some sort but that isn't a distinction on your RV as to where it originated from.
Rubiranch
Fremont Indian State Park
Posted: 04/30/09 08:22am Link  |  Print  |  Notify Moderator
Put the pressure regulator on the faucet and then your hose.
Our campground has soo much pressure it causes the white hose to swell.
Rubiranch
Posted: 04/30/09 08:29am Link  |  Print  |  Notify Moderator
"fresh water hook up & city water connection"
Me too skip, looks like one in the same to me too.
Rubiranch
Posted: 04/30/09 08:30am Link  |  Print  |  Notify Moderator
MSGMadhatter
Oklahoma
Posted: 04/30/09 08:58am Link  |  Print  |  Notify Moderator
Fresh and city water:
TTs have two water hook ups. One, you attach a hose to and leave it on for continuous water.
The other is a little door, you run water into it like filling a car's gas tank.
People that camp without hook ups, use this tank. When you run out of water then you have to fill the tank again. This water is circulated through out your RV water system by the water pump.
City water, you don't use the water pump. The water is by-passed. The pressure of the water coming from the faucet to your RV circulates the water.
MSG MADHATTER (Life Member Good Sam)
1500 HD Silverado, 6L
Jayco Eagle Super Light 298RLDS (Hers)
Jayco Greyhawk 24SS Class C (His)
