desertfam
Sunny SO CAL
We are shopping for a used DP, years range from 01'-06'. I would like to know if there are any Diesel engines that I should be aware of?
My grandfather (truck driver and former DP owner) was always a fan of Cummins. I am also partial to them, but would like to keep an open mind.
We are shopping for floorplan, but I would like to have something 300hp or more! We will be towing a 20' Enclosed trailer.
Thanks in advance
"Live everyday!"
04' Fleetwood Bounder 32W Workhorse W20 (FOR SALE)
07' 20' Enclosed Trailer
06' Chevy 1500hd 4x4
03' Z400
04' Predator 50
04' Predator 90
05' Suzuki JR50
04' Honda CRF50
One excellent wife, Two awesome Desert rats,no problems
JFG
TN
Cummins makes an excellent engine. You do want to avoid one model... This defect involves Cummins ISL CMS5O diesel engines produced for recreational
vehicle applications between October 17,2005 and April 18, 2006. They had a machining problem in the wrist pin area that would cause the engine to seize up. the fix was to add a monitor to advise you when this was about to happen.
Fred
don/lou
Brandon MB Canada
Good Sam RV Club
I would stay away from these ones
Cummins Recalls 2,159 Bad Rv Engines for Piston Rod Failures
ISL Cummins CM850 Diesel Engines, made for recreational vehicles:
Made between October 17, 2005, and APRIL 18, 2006
Engine Serial Numbers range from 46543077 to 46603939
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
bkd148
Spanaway, WA.
If you are going to pull a 20ft. enclosed trailer make sure the motorhome your looking for can handle it. A lot of DP,s only have a 5000lb. hitch. It is very easy to find once you put 200lbs. of wieght on the hitch you are over wieght on the rear axle. Marty
2002 Beaver Patriot Thunder
Cat C-12 455hp. 6spd. Allison
2002 Jeep Wrangler Sahara
jahapp
Wherever the soft breeze blows
JFG wrote: Cummins makes an excellent engine. You do want to avoid one model... This defect involves Cummins ISL CMS5O diesel engines produced for recreational
Quite true, but the ISL 400 in general is outstanding. Of the engines recalled, only 60 had the problem with piston wrist pin failure, but they could not tell which 60, so they recalled 2,000 engines. All failures occured in the first 10,000 miles, most in the first 4,000. Mine has 57,000 miles and has been perfect.
Ivylog
Blairsville, Ga. USA
In those years and 400 HP or less, it does not make any difference although I'd stay away from the small 5.9 Cummins with only 600 ftlbs or less of torque to pull your trailer.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
v8q
Oviedo, FL
By mid 2001, competition among manufacturers was such that just about any DP above entry level had a 10K rated hitch. By 04/05, many were offering 18K rates on the higher end models. Mainly due to use of enclosed/stacker trailers.
Dave Head
Oviedo FL
95 Foretravel U320C SE
M11, HD4060
Dog Trainer
Richmond Mi.
I agree that the 5.9 is probably a bit light for jobs pulling more than 25,000lbs GVW. If you did look at a 5.9 stay away from the dreaded 53 block. This can have a problem with cracking.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow (fur Bearing Children)
desertfam
Sunny SO CAL
Thanks for the input, that was exactly what i was looking for.
I forgot to mention that I am looking for one with 10000# towing.
Fishinghat
Western Washington, USA
The 5.9 (ISB) is probably too small for your needs, so the ISC or ISL would be more appropriate. Both would serve you well.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
