Hi all, I have a new Prodigy brake controler, have it installed and discovered that I burned the box with the instructions to adust it. CAN ANYONE HELP if you have your original papers, could you e-mail a copy to me.
my e-mail is: stutrud1@wbcable.net
Once you get ajusted write down your amps with the lever on. That way if you can get back to the same point or add power without going throught the whole procedure again. I haul a toy hauler and when it gets fully loaded up I can feel the need for more trailer brake. I just pull the lever over at the next stop light and with it on ajust dial to add .2 amps. This is a small but meaningful ajustment.
