RV.Net Open Roads Forum: Question about gas inverter generator for RV
 > Question about gas inverter generator for RV
Cousin_Eddy
Peoria, AZ
Posted: 05/13/09 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Last camping trip there was a newer DP in our group. It had an inverter generator built in. You could barely hear it running and it was a pleasant sound. I have been searching to see if there are gas ones available for RVs but haven't found one. At least, Onan doesn't have one. If there is one, please point me.
I know about the portable Hondas and Yamahas, but I am looking for a replacement for the built in.
After that camping trip, our genset seems noisy.
Thanks!
1995 33' Southwind Fleetwood Model LW
stacaz822
Phoenix, Arizona
Posted: 05/13/09 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Vibration dampening, foam rubber sound insulation, and a better muffler can do wonders. Probably a lot cheaper, too.
Stacaz
YC 1
Yuba City Calif.
Posted: 05/13/09 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
The 8KW diesel generator on our MH is quieter than our 4KW "microquiet" generator was on our last mh. Just for grins I set my Honda 1000W generator next to the exhaust of the 8KW unit and I swear the diesel was just as quiet if not more. I have no idea how they do it. Maybe the diesel is turning much slower rpms. The most noise from it is the intake air noise.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
Cousin_Eddy
Peoria, AZ
Posted: 05/13/09 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds like the one, actually I think the DP was an Endeavor. They were 5 feet from my RV and it took me a while to figure out what that noise was. Couldn't believe it was their generator.
Maybe you can't get one like that in a gas unit yet. But, it seems like it would be easier to make a gas engine quiet.
PR Connection
Powell River BC
Posted: 05/13/09 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I had an Onan 4000 micro quiet in my Bigfoot class C. I found it very noisy also. I too have been up close to high end class A's with a diesel genset that was super quiet. I finally yanked it out and replace it with a modified honda 3000. Here is a link to my thread over in the Class C forum.
genset replacement pics
It is super quiet and love this modification so far.
Dan
2006 3000SL26 Bigfoot Class C
320 Watts Solar With Bluesky 2000 Regulator
Four 6volt U2200 Batteries
2000 Watt PSW Magnum Inverter
jauguston
Bellingham, WA
It costs a lot of money to design and manufacture a generator that has to be super quiet. The market for the portables like the EU Honda and some others is a hundred times or more larger than the market for a built-in. For me the ultimate would be a inverter version of the Honda EV series. I had one and it was a good generator with a water cooled engine but it ran at a constant 3750 rpm and it was noisy.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
YC 1
Yuba City Calif.
Posted: 05/13/09 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Was it the Endeavor in my picture? Just kidding. But the generator is incredibly quiet.
Cousin_Eddy
Peoria, AZ
Posted: 05/13/09 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Dan
Wow! Nice installation. I suppose this could be a solution for me. Probably cheaper than a built-in if it exists.
Cousin_Eddy
Peoria, AZ
Posted: 05/13/09 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
It looked exactly like yours. If you look like George Lopez, tell a lot of jokes and you own a sand-rail upolstery shop, then it was you! I forgot the guys name though....it wasn't George.
C5man
West Coast
Good Sam RV Club
Posted: 05/13/09 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
DPs have watercooled diesel generators. Generally, watercooled internal combustion engines are quieter than aircooled engines no matter what they power. Water jackets generally insulate sound better than air cooled cylinders with fins, like early VW Beetles vs later ones, or water cooled bikes vs air cooled bikes.
