RV.Net Open Roads Forum: Tech Issues: Thermo Pane Windows
 > Thermo Pane Windows
Tech Issues Related Tips
Jay58
Central Florida
Posted: 05/17/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone here replaced, themselves, the window panes in their motorhome? I am getting ready to split one front windo to take one layer of the glass to a glass shop and get pricink for new ones using one layer as a pattern and retaining the other to temporarily keep the rain and weather out of our coach, any suggestions or advice is appreciated.
1996 HR Endeavor 37.5
230 ISB, 6 spd. Allison
Central Florida (East Coast)
Warren&Karen
Austin, Texas
Posted: 05/17/09 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I've done it. Saved a TON of $$$ over the cost of a replacement window.
I took my time in separating the frame from the window glass segments, also was careful to put a bead of sealant on the leading edge and top edge of the frame when I reinstalled the unit.
Karen and Warren
"Counting the days 'til retirement"
Sophie and Sam, our two Yorkies.
Austin, Texas is home. Also, look for us
at our getaway in Rockport, on the Texas Coast.
2003 38GH model Tiffin Phaeton
avan
Sioux Falls, SD & Livingston,TX
Good Sam RV Club
Posted: 05/17/09 11:09am Link  |  Quote  |  Print  |  Notify Moderator
What does this have to do with campgrounds and attractions??
Click for more pics of our FT home, our snowbird digs and our summer trips
The puller - International 4700LP (530E) - Wiers Towmaster; Trailer-Saver Air Hitch
The pusher - 40' Travel Supreme Fifth
Litch
Truckee, CA
Posted: 05/17/09 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Seems from his profile he is a New Member. Maybe made a mistake, I'm sure it wasn't intended to rile anyone.
To the OP, maybe ask the Mod to move it to the correct Forum. Also, welcome to RV.net, tons of good info here.
2006 Chevy HD LBZ Duramax/Allison
2006 Holiday Rambler Savoy 30sks
answerswillvary
eastern washington
Good Sam RV Club
Posted: 05/17/09 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Campgrounds, Resorts and Attractions
Check out the RV.NET BLOGS at blog.rv.net
Jay58
Central Florida
Posted: 05/17/09 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
OOPS thought I had it placed correctly, Yes I agree It dosnt belong in Campgrounds, Moderator, thanks for moving this.
YoBubba
Posted: 05/17/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
This may help !
Atwood Window Condensation Repair
RVUSA
Orlando, FL, USA
Good Sam RV Club
Posted: 05/17/09 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Talk to the folks down in hudson, they can help.
suncoastdesigners
1995brave
San Antonio, TX
Posted: 05/18/09 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I had to do both my front side windows. Found after the seal broke the inside panes got etched. This is how i did mine. Took out the windows and measured the depth, removed the inside pane and seal, and measured the outside window. Subtracted the two and got the thickness i would need to put the single pane back in the frame. Went to the local Home Depot and found some plastic moulding that was very close to the thickness i needed. Shaved it down to the correct thickness, cut it to match the glass outline(several pieces), painted it black, and RTV'd it to the glass. Put the rubber seal back around the glass and shim and installed it back into the frame.
