hmalaga
Malaga, WA
I have an 05 Holiday Rambler 28' Savoy. The plastic molding that is attached to the side of the trailer on both sides above the wheels is cracking/broken but still attached. I believe it just stress as it is happening at most of the screws that hold the plastic molding on. I went to our local dealer for a replacement piece and he said Monaco (Spelling) was in chapter 11 and I could not get a replacement at this time. He suggested that I take tin and rivet it behind the plastic to keep it together. Obviously, their repair shop could do it....I am wondering if anyone else had encountered this and tried a repair. I was thinking about placing Eterna bond tape behind the cracks instead of rivets....My son-in-law suggested I try epoxy but I noticed that most epoxy says it works on MOST plastic sooooooooo any suggestions would be appreciated
bldrbuck
Boulder, Colorado
Good Sam RV Club
Parts Page
you may find them here.
WOJO 1
Sparks, Nevada
RVSurplussalvagedotcom
2002 Duramax 4X4 CC SB
2005 Cougar 296EFS
Reese 16K Slider
2 Hondas in the front storage compartment
TTT Mirrors
jeb5
Western Ohio
Good Sam RV Club
I used Gorilla Glue (Gorilla Tape and then Gorilla Glue) That has been about 4 years ago. Can not see it unless I show it to you. I crack, vertical, from screw to bottom flair.
Ford F-250, V-10, 4:30LS
Newmar Kountry Star 5th Wheel
pdinaj
Apache Junction,Arizona
If you absolutely cannot find a replacement, take it to a bodyshop. They can make a new one out of fiberglass, or repair the old one if it's not to badly broken. If you use gorilla glue, make sure the place where you glue it is damp or the glue will not work.
Boca_Shuffles
Pinckney, MI
Good Sam RV Club
If you want to buy new skirts, this site has them.
http://www.icontechltd.com/productcart/pc/Tandem-Axle-Fender-Skirts-c13.htm?gclid=CIKe5-6J2JoCFQJ-xgodOg2aFg
This might be especially helpful for "orphaned" trailers.
Tom & Bobbi
2008 GMC Duramax DRW
2010 Bighorn 3055RL
Michigan
02super250
around
Good Sam RV Club
If you get new ones make sure you make the holes larger then the screws. that way they wont crack again.
2007 F350 Lariat 4x4 CC DRW Powerstroke 4:10 brake controller
2007 Keystone Challenger 29TRL Fifthairborne.
BudnLiz
Conyers, GA
Good Sam RV Club
Monaco's website is still up. Try going on it and emailing someone with your question.
Good luck, Bud
2007 Jayco Eagle 288RLS The Jaybird
2006 Dodge 2500 Mega Cab 5.9 CTD
TruControl, Hensley Arrow
Schnauzer- Sir Winston
