RV.Net Open Roads Forum: Truck Campers: Tiedowns??
 > Tiedowns??
Truck Campers Related Tips
billyray50
Dallas
Posted: 05/23/09 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Hello, Newbie to truck camping. I am looking to buy a used truck camperhard side. This unit only ways 1250 lbs. I drive a 2006 Dodge single axle turbo deisel 4x4 with 8' long bed. Will the stake pocket brackets be enough to transport camper from Las vegas to Dallas, TX or do I need more equipment? Best regards
monkey44
Cape Cod, MA
Posted: 05/23/09 11:52am Link  |  Quote  |  Print  |  Notify Moderator
If I did it, I'd get the permanent tie-downs before you pick it up. Happi-jacs or Torklift are good products - and are usually available at any RV dealer that sells TC's ... so if you're not sure you're buying it, and are going to inspect first, you can go locally there and have the tie-downs installed. And you might need the electrical connector too -- Takes a couple hours.
Personally, I'd not trust stake-pocket connectors. You're talking a pretty long trip and on interstate highways ... not just across town.
Monkey44 Cape Cod
GMC 2500 4x4 Sierra X-Cab
2008 Lance 845
2002 Angler 8B
Back-country camping fanatic
snowolf
buchanan, michigan
Posted: 05/23/09 11:54am Link  |  Quote  |  Print  |  Notify Moderator
dont think i would over the rockies but my parents did it in the early years with their 1st TC. trust me some sort of frame mounts will make the truck ride much more stable being that you have a single wheel rear axle.
i made mine frame mounts. i have 3 out of the 4 original stake bed mounts from my parents 72 ford f250. kinda funny to think those held that camper over mountains,winds,snows, etc........by the way they are kinda "tweaked".
also double check the fitment to your truck new trucks and old campers dont work well together.
I bought an 85 real-lite(1800lbs empty) and it rides on my 2000 f350 dually. i only have about an 1" fudge factor on all the clearances. had to make extensions to get the jacks out of the way of the dually fenders. had to make jack extensions to get the camper up high enough to clear the foam i used to clear the cab. BUT i got it on.
mine cant move much cause theres no where to go except off the truck!!!!
http://www.facebook.com/photo.php?pid=6088&l=3b402d7303&id=100000024841835
snowolf
buchanan, michigan
Posted: 05/23/09 11:58am Link  |  Quote  |  Print  |  Notify Moderator
http://www.facebook.com/photo.php?pid=6086&l=23d3d56a9d&id=100000024841835
JimBollman
Upstate NY
Posted: 05/23/09 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Even if they do hold ok the camper will feel much more stable when it is tied into the frame. Lots less flex.
I switched many years ago and could not believe the difference.
Jim...
~DJ~
Boise, Idaho
Good Sam RV Club
Posted: 05/24/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
I would not trust the stake pocket hold downs in any newer truck. They worked OK in the older rigs when they still made bed/boxes from steel vs aluminum foil!!!!
I also vote for frame mount.
Good Luck.
2010 F150 Super Cab XLT 5.4 4X4 Short Box
1988 Nortstar 8' pop up TC
Honda 2000
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
fueling around
NW MN
Posted: 05/24/09 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I hauled me camper home with stake pocket ties. I hit 55 mph once or twice, but it was mostly a 50 mph drive for the 200 mile trip.
If it was a pop-up style low profile camper they may work. I would spring for Happijac or Torklift
DITTO
John
1997 Dodge 2500 CTD
1989 Cascade 8½ Self-contained Truck Camper
?? Eureka Timberline 4 tent
enine
OH
Posted: 05/24/09 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I put the stake mount bars in my truck to bring the camper home and they bent the stake holes a little bit, but I can flex the steel there with my hands so its not real strong anyway. I'm thinking about using the tie down points in the bottom of the bed.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/24/09 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
The over the bedrail clamp on tie downs will work fine for that light weight camper. Pop used them on his camper and I used them on both my campers on 2 different trucks before I built the frame mount tie downs for my last camper before I sold it. Put them on and take your trip, no worries.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
enine
OH
Posted: 05/24/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
what year trucks did pop and you use them on? The bed sheet metal is thinner on newer trucks. I bent mine just coming home.
 > Tiedowns??
