RV.Net Open Roads Forum: Folding Trailers: tire pressure
 > tire pressure
Folding Trailers Related Tips
lighthouse12
nova scotia-canada
Posted: 05/24/09 06:20am Link  |  Quote  |  Print  |  Notify Moderator
I have 98 dutchman 8 ft wondering what psi should be in tires-
trailer is not loaded with stuff other then the usaual -blankets,clothes and food the max pressure on sidewall is 55 lbs
at max weight but I,m not at max -so whats a ball park pressure (i was thinking 40)
Turbo Diesel Dude
Green Mountain, NC
Good Sam RV Club
Posted: 05/24/09 06:31am Link  |  Quote  |  Print  |  Notify Moderator
55 psi. Tires will last longer and perform better.JMHO
charles weidman
dbbls
Missouri
Good Sam RV Club
Posted: 05/24/09 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Run the max pressure listed on the sidewall. Tires will run cooler and heat is the enemy of tires.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
skipnchar
Topeka Kansas USA
Posted: 05/24/09 08:25am Link  |  Quote  |  Print  |  Notify Moderator
You probably COULD run lower pressure but can't think of any REASON to do it. The SAFE way is to run maximum.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Chuck&Gail
In the Colorado Mountains
Posted: 05/24/09 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
IMO you load it to the maximum weight it will ever be., Then you WEIGH it. Then use the manufacturers tables (after all, they MAKE the tires, so they should know best) to determine the pressure to use for YOUR load with YOUR tires.
Most trailers have marginal tires when new, but not all do. Also not everyone feels the need to load their trailer up the the maximum GVWR. Only you know where you fall in that spectrum.
Most gravel lots, feed lots, etc have scales.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
FF-Mike
Lannon, WI, USA
Posted: 05/28/09 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Chuck&Gail has the correct answer. I do not see how maxing out a tire can be safer when there is less lateral traction and less braking ability. Not that I rely on my trailer to be able to do either.
99 Suburban K1500
88 FlagStaff M-621
5 little girls growing up tooo fast
pcfeld
Eastern, IA, USA
Posted: 05/29/09 01:16am Link  |  Quote  |  Print  |  Notify Moderator
I suggest running them at max as I believe my blowout was due to low air pressure on a utility trailer. One tire was @ 55, and the other at 45 with max on the sidewall being 55. Since I was only carrying bulky items, 500 lbs. I didn't think it would make a difference. 1 hour later I was changing the tire along side of the road on the low pressure side.
Pat ('66)
Sandi ('67)
DD ('92)
DS ('95)
DS ('03
2001 Town & Country
2004-Rockwood 2280
A few pictures
rrupert
NW PA (Oil Heritage Region)
Posted: 05/29/09 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Do you vary the tire pressure on your car depending upon how many people you are carrying? I think not. Most people set their tire pressure according to the car maker's recommendation. That is usually less than the tire's maximum pressure, but it is what is recommended for that particular vehicle. On my trailer I go with what the sticker says for tire pressure.
My bottom line is that I check tire pressure on a regular basis to make sure it is up to where it should be. It is allot easier and safer than fixing a flat along a busy highway because I was running an under inflated tire.
Joyce and Rich
2005 1705T HiLo turning into a
2010 HiLo 2310H when Spring Arrives
2007 Toyota Tacoma Crewcab
Amatuer Radio K3EXU
RandACampin
Kathleen, Georgia
Posted: 05/29/09 09:13am Link  |  Quote  |  Print  |  Notify Moderator
What size and brand of tire? I say maximum is always the SAFEST way way to go, I just curius if we can find a weight/pressure chart for your size tire.
-rog
FF-Mike
Lannon, WI, USA
Posted: 05/29/09 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Maxxis ST Tires
 > tire pressure
