RV.Net Open Roads Forum: Fifth-Wheels: Nitrogen in tires
 > Nitrogen in tires
Fifth-Wheels Related Tips
Ford Man
Tennessee
Posted: 05/26/09 12:00pm Link  |  Print  |  Notify Moderator
Has anyone used nitrogen in your 16" 5th wheel tires? I have read so many articles about how they will maintain pressure better than air and thought this might be better in trailer tires.
Vulcaneer
Northern New England
Posted: 05/26/09 12:13pm Link  |  Print  |  Notify Moderator
I think the general feeling is that if you can get it done for free go for it. If you need to pay for it the advantages are not worth the price. May help the tires from losing pressure while standing. But that is pretty much it.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
Capt Skup
Southern Maryland/Nantucket
Posted: 05/26/09 12:23pm Link  |  Print  |  Notify Moderator
I just use what comes out of my compressor. Never had any issues. I do check my tires about once a month for proper pressure and rarely find that it has deteriorated. I would never pay for a shop to pump distilled nitrogen into my tires, I would for one be dubious of their ability to remove pre-existing air held within the tire.
Fun reading:http://scifun.chem.wisc.edu/CHEMWEEK/PDF/airgas.pdf
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
'08 F-450 Lariat 4x4
'08 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
2manytoyz
Central FL
Posted: 05/26/09 12:31pm Link  |  Print  |  Notify Moderator
I put 78% nitrogen in my tires. Been doing it for years before it became popular.
I lose less than 1 PSI per month. My tires rot from the outside (UV), never from the inside.
I rate this one right up there with fuel line magnets, Slick 50, and a vortex intake device. Snake oil.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
2010 Ford F-150 FX4 -w- Max Tow Package
Yamaha EF2400iS
http://www.2manytoyz.com/
camping man
Central Fla.
Posted: 05/26/09 12:32pm Link  |  Print  |  Notify Moderator
If it's free why not,but saving 1.5 psi a yr. is hardly worth it, and I think the air is about 78% nitrogen anyway.
05 Dodge CTD 2500 / 97 Sprinter 5er
doughere
Mooresville NC
Posted: 05/26/09 12:44pm Link  |  Print  |  Notify Moderator
I don't know what 2manytoyz is talking about. Ever since I installed my intake vortex device, I find my turning radius is 14.7% better. He probably doesn't have his fuel magnets aimed correctly. I've also found using Slick50 keeps the snake oil at the proper pressure; I don't loose more than 2 farads a month with it.
I do use about 78% nitrogen in my tires though, it doesn't cost a bit extra!
Doug
MSGTRETIREDCSP
Burlington, Colorado
Posted: 05/26/09 01:04pm Link  |  Print  |  Notify Moderator
As stated earlier - snake oil.
2008 Ford, F-350, CC, 6.4 PSD
2003, 2955 Montana 5th Wheel
houtrz
Lake Jackson Texas
Posted: 05/26/09 01:20pm Link  |  Print  |  Notify Moderator
I too have read so many things about nitrogen in tires and I think it would make a difference in exteme temperature changes because the nitrogen is suppose to be more stable than an oxygen/nitrogen mix. In my van we have onboard pressure monitor on all four tires. In the hot Houston summer, I can take off with cold tires and after a few miles on the highway, I'll see the pressure increase 3-6 psi. Not sure if thats a big deal though but I"m betting pure nitrogen would reduce that. I'm also betting that with an increase in pressure comes an increase in temperature, again not sure if thats a big deal though.
From what I understand race cars and airplanes use nitrogen, I"ve heard to reduce fire potential and reduce pressure/temperature variations. Not sure if its needed on an everyday car or RV.
kaydeejay
SE Michigan, USA
Posted: 05/26/09 01:28pm Link  |  Print  |  Notify Moderator
DRY air follows the same Boyle's Law for gases as DRY Nitrogen. Introduction of water vapor introduces a degree of variability and instability.
Race car teams use Nitrogen bottles as it is a) dry and b) provides a lot of volume very quickly.
For the average driver there is no economic advantage. If it's free, as others have said, there is no downside.
That said I am a big supporter of the "78% Nitrogen because the price is right" brigade!
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
Dave H M
IL
Posted: 05/26/09 02:49pm Link  |  Print  |  Notify Moderator
I can see you did not do a search on the subject.
If you really want a payback use helium. It helps lighten your load.
 > Nitrogen in tires
