Nice kit and Dexter is selling at about half price from thier website.
Thanks for the tip! I've been wanting this kit since I first saw it. At that price I couldn't help myself. I felt I should help out with Dexter's Inventory Reduction sale. it was the right thing to do...
nayther,
We have the same Rage'n and a shackel failed on mine 2 years ago. My Dexters show zero wear.
BTW, on greasing the zerks, don't be stingy, they will take plenty on the initial greasing. It's messy but let is ooze out, the brass sleevs will wear out faster w/o sufficient grease than the stock dry plastic sleeves will. There is no seal to blow so grease away!
A productive weekend for us both, I just removed the stock 2 battery cage and welded in a new 4 battery cage for 4 -6v's. It's a tight fit, but they are in there!
Definatly something to keep an eye on. At work we have some 4' X 8' dump bed trailers, We change those shackles/bushings/etc all the time, never occured to me that Us T H peeps have the same setup
Bob J
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
2008 KTM250XCF-W
MEMBER AMA and CORVA
2BlueHeelers wrote: nayther,
Thanks, I'll hit them with more grease now, only put in a couple of pumps until some oozed out, I'll get more in there before Friday's voyage. Would love to see how you got four 6v batteries in there, wanted to do that for some time, can you post a pic?
Now that you mention it I remember you had a catastrophic failure a while ago didn't you? Guess I should have been more observant then.
As long as grease oozes out you should be good, but give em another blast after your first trip.
Quad 6v batteries no problem in the Ragen FA3005 -it just makes the PIN heavier! Cut out the old battery frame, make a new one to fit your layout(boxes or not). I added a cross piece to the trailer frame to support battery box frame near the generator.
Here is mine:
Got the battery boxes at Fisheries Supply. They are available to order online.
DuneMe wrote: Does anyone know if this is the kit I need?
http://dexteraxle.com/inc/sdetail/28011
Thanks.
Hey, Dune did you measure the axles? I am curious too. I saw the price and thought is was a misprint. It was like $500 bucks awhile back. I think I will get the entire kit, I can't get some of my zirks to take grease now.
